As far as I know the airbags have gone NLA a long time agoCan you get new Airbags? Or is it just the rim of the wheel w/o the center
@TimL, you’re SO gonna love how this thing shifts when you get it back and get the Bowden cable and vacuum modulator dialed in! That flex disk is going to make a huge difference, believe it or not. I was shocked how much crisper was the chassis feedback. Enjoy!My car has been sitting at MB for the last three weeks, held up by slower than usual part shipping. New torque converter and remanufactured transmission showed up recently though and work has started. The sportline steering box is going in and so is a new rear main seal. Also having a NOS cruise control switch and new steering wheel installed (surprised that MB still sells the steering wheel, so I thought I'd get one in case they go NLA). My front flex disk was about to disintegrate, so good thing it has held up until the transmission replacement. It should all be done by Wednesday. Since it's been a while since I've done a road trip, I decided to go to the IMSA race at Laguna Seca at the end of April and I'm really looking forward to a trip down the West Coast!
Awesome to hear, maw! The thing that has been bugging me with my old transmission was the 2 sec reverse delay. Everything else was fine, but if the transmission change delivers more improvements, then I'd be super happy!@TimL, you’re SO gonna love how this thing shifts when you get it back and get the Bowden cable and vacuum modulator dialed in! That flex disk is going to make a huge difference, believe it or not. I was shocked how much crisper was the chassis feedback. Enjoy!
@TimL did you use 129-460-19-03-7102? That price doesn't seem unreasonable actually...... and new steering wheel installed (surprised that MB still sells the steering wheel, so I thought I'd get one in case they go NLA).
Heh, guilty as charged. Except I use screwless wallplates.Pot...kettle....something something black?
OK Holy Moly, that is too rich for my blood. Yikes!-7102 is likely NLA, and I'm not sure what color that is.
-9045 is what Tim has (black). Wee bit painful, but new ones are soooo nice. I stupidly sold a NOS one I had years ago. *sigh*
@Jlaa , no, unfortunately no one had -7102. I had to buy -9045@TimL did you use 129-460-19-03-7102? That price doesn't seem unreasonable actually...
Heh, guilty as charged. Except I use screwless wallplates.![]()
www.instagram.com
Tim, the liquid/moisture is a non-issue unless you have misfiring that recurs often enough to be a problem, AND does not go away after a long drive to get everything fully heated. Slotting should significantly improve the issue if you live in a humid area (@JC220 reported excellent results from a green area of UK). Wiping the caps clean is usually all that is needed, you absolutely should not need to replace the components annually. If you do, I'd happily take your old/discarded items!Just got a picture of the caps that were installed a year ago. They had quite a bit of moisture in them (see picture). Spoke at length to Steve Geyer about it and he said that none of the things that he tried over the years has remedied the issue of moisture accumulating on these parts (be it slotting drilling or, coating).
LOL. Yeah, that involves replacing the engine management with something completely different. I'd like to know the details of what Bernard has done, as most of the time the ECU conversion means losing the factory CAN ecosystem (ditching LH, EZL, E-GAS, everything else) and relying on aftermarket fuel & ignition curves, including aftermarket knock control etc. This may work but also may not have Mercedes-level engineering or functionality. Need more details than a 5-second Instafacetweet video.He did share this link from Stern Garage though- seems like that guy, who is running a well known MB repair shop in Germany, has figured something out![]()
JC, I agree this is one likely source. However my car referenced above had new cam seals and that area was 100% dry, while the cap had a healthy dose of oily liquid inside - hence my theory there may be more than one potential source for the oil.I believe it is a mixture of crankcase gases and engine oil spotting from the cam seals.
I believe the genuine MB caps used to come with a clear varnish/coating, but I am not sure if they still have this. The Beru caps do have the clear varnish, but are NLA.Yet others believe only the genuine MB caps come with a special clear unverified varnish which makes them superior.
I agree with this 100%, after the oil leaks are cured and new ignition components are installed!Personally I think none of this really matters. Just follow every step of the Ignition Thread and it should be AOK. Occasional bi annual smoo checks will probably be a good idea also.
Thank you @a777fan - hope you’re doing well and that V12 of yours is producing lots of smiles per mile! We ought to grab a coffee. Would love to see Uter’s new stablematebet it feels amazing tim! Looks awesome as usual![]()
Awesome! That will go a loooooooooooooooooooong way for you to enjoy your car even when it is parked!
Tim, a friend bought one last autumn together with a new steering wheel. It was still available, but very expensive! Around 2.5k If I remember correct.As far as I know the airbags have gone NLA a long time ago
Because I‘m stubborn and because I hate the bulging lower dashboard with considerable passion I bought yet another lower dashboard to see if it will fit. I followed @speedy300dturbo ‘s advice and searched for a first gen U.S. dashboard instead of the euro dashboard I had bought a while back (which wouldn’t fit without some additional support brackets that I was unable to source). Have an appointment at MB on Tuesday to make yet another attempt. We’ll see if this works…I am determined to make this POS work as I am 100% done with the look of the bulging U.S. lower dashboard. Some sort of support bracket is missing in the back to hold the panel in place, so I need to figure out more about that. Once I do and know the P/N, I will try it and let you know if it works.
Dave, it was advertised as being from a 1987 w124. Will find out on Tuesday if it fitsTim, that piece doesn't look correct... what year/model is it from?
That looks like standard issue North American underdash panel from a late model W124. Notice the protrusions below the headlight switch and ignition keyhole area.Tim, I'm 99.44% certain that is not from a 124 chassis. Maybe @speedy300dturbo recognizes it?
Yep, you were right - the panel was advertised to be 124-680-21-87 (no bulge) and it ended up being 124-680-53-88 (bulge). Would be awesome if anyone had a non bulging version in black for sale... it's not the "slim" early version... it's the late version, possibly the same as what you have now?
Did the seller state the exact year and model it came from? Or was it advertised as "fits" early 124? The latter is pretty common on the 'Bay and causes all sorts of problems when you are looking for something from a specific year range.
We were just discussing the same scenario with my cousin, he bought GTI for his wife, and it too has the "noise enhancer" build in, said it was driving them nuts... Luckily, VW crowd is in abundance, and there is an aftermarket "software" fix to delete this option that he used/bypassed.Really hope the new replacement gearbox works out of the box unlike the one they installed a couple of months ago. I guess we’ll see.
On a side note, just drove from Frankfurt to Hamburg today with a Skoda wagon rental car and we do indeed live in strange and disturbing times when this 4 cylinder family car maxes out at 265 km/h according to the tach. This uninspiring family hauler would blow the doors off the 036 in a straight out Autobahn run any day of the week and somehow I find that thought mildly depressing. What is REALLY depressing is that this thing pumps fake engine noise through the speaker system, making it sound on the inside like a v10 and when you lower the window you realize that in reality a bland and muffled 4 cylinder noise emanates from the car, sort of like the mechanical equivalent of a yawn. Amazing, in all the wrong ways. Sorry. Rant over.
Tim, do you get home sick or has US and Seattle eclipsed your past life in Germany?I’m In Germany again for a couple of days and on Friday ordered all the parts needed for the E/S switch installation at the German MB dealership in my hometown.
Yeah, particularly the pace of change is unsettlingThis uninspiring family hauler would blow the doors off the 036
This is a fascinating conversation. As my wife is a legal immigrant and I am the product of legal immigrants, I have seen this same story unfold over many decades. I think what happens is that in the first two decades, the home-sickness is there, and frequent travel back to the "mother/father land" is inevitable. Many if not most of your friends in the USA share your same experience - also immigrants to the USA from your "homeland."Difficult question, @Kyiv . On the one hand I miss my friends and family in Germany (parents, brothers and their families), but at the same time I found my wife here in the U.S. who is my everything, so I am lucky that my job takes me to Germany at least 6 times a year, allowing me to not lose touch with my folks there. How is it for you? I
We seem to have a minivan-loving contingent on this forum. I thought it a bit odd with @600Eric and his love for the R-class, but as I said in another comment, it has really taken a turn for the surreal. However, I pass no judgement on the individuals involved.....Yeah… I hate the ”creation” that is engine noise through the speakers almost as much as the creation that is minivans.
Yes @Jlaa , I am sure that this is the experience of the vast majority of long term expats and while not necessarily an easy position to be in, it is, as so many things in life, a matter of attitude you take towards it. The older I get the calmer I look at this conundrum. The last thing I want to do is trying to be the jack of all trades only to end up messing both things upThis is a fascinating conversation. As my wife is a legal immigrant and I am the product of legal immigrants, I have seen this same story unfold over many decades. I think what happens is that in the first two decades, the home-sickness is there, and frequent travel back to the "mother/father land" is inevitable. Many if not most of your friends in the USA share your same experience - also immigrants to the USA from your "homeland."
Eventually, one has kids. Those kids grow up in the USA and speak English. The kids can still speak the mother tongue if they try hard and learn, but without 100%-all-the-time practice, English will always be stronger than the mother tongue.
The kids grow, and you make friends with other families here in the USA --- you start to set roots here.
You take family vacations back to the mother/father land, but, over time, you notice things at "home" have changed. It isn't the same "homeland" exactly as you remember. And, of course, your kids feel some kind of cultural connection, but they don't have the same tight connection that you do with the "homeland." They don't have the same nostalgia.
Your kids grow and become young adults. Once your parents in the "homeland" pass, if they have not done so already, a critical bond breaks. Your connection becomes less tight. You also see more changes in the "homeland" and, after perhaps 3 decades away from the homeland, you start to feel a bit like a stranger when you visit the "homeland" because the politics and the culture of the "homeland" have diverged from your memory - it progresses without you.
The decades pass. Maybe 5-6 decades later, you pass yourself, but more likely than not you choose to be buried/cremated in the country that adopted you - the USA. I have seen things unfold along this path and I think it is quite rare that things do not work this way.![]()
Dropped my car off at Mercedes in Lynnwood earlier this week to get another MB replacement gearbox installed. Steve is running all the lines required for the E/S functionality but won't hook anything up just yet, so as to avoid any potential conflict with any warranty claim in case this one turns out to be faulty too (hopefully not very likely).I’m In Germany again for a couple of days and on Friday ordered all the parts needed for the E/S switch installation at the German MB dealership in my hometown. Thankfully all the required parts are still available and should arrive before I leave again next Sunday. When I get back to the U.S. I’ll drop those parts off at MB, as the replacement gear box has showed up earlier this week, so the box and E/S functionality can be installed at the same time. I totally understand that this will just introduce the low shift point Economy function, but to me it’s a memory of my youth. All the MBs my mom and dad drove in the 90s had that E/S switch and to me the interior just doesn’t look right if it’s not there- just like the big U.S lower dashboard pad that also just looks plain “wrong” to me (crazy, I know, but to each their own). The dealer in Germany was so kind to photocopy some of the old wiring diagrams, so Steve has some guidance on what connects to what when I hand him the sack of parts next week. He won’t be thrilled about the E/S thing but that’s ok.
