I have a '92 500E which had a slow start problem for a few months, so I decided to read the forums here. As a result, I tested the fuel pressure, which was spot on when running but dropped too quickly after shutdown. I have the early 2-pump arrangement with the replaceable check valves, but after reading more I decided to change out both pumps, filter, the tank check valve and all hoses at the tank and pumps. Used Bosch pumps and dealer parts where available for the rest.
Someone had likely changed most everything before as some of the spring retainers were broken around the tank vent hoses. I ended up not changing the supply line from the tank to the pump as it seemed in very good condition, and I couldn't get it off from below and didn't want to remove the gas tank or risk having to do so at this time. I had drained all the fuel out of the tank including what was in the return line from the FRP.
When done, I added about 3 gallons or so to the empty tank and tried to start the car, both with and without the accelerator pedal pressed down, and with and without gas cap on. No start. When the key is turned to the start position without cranking, there is no power at the pumps or audible pumping action, specifically, no sign of 2-second run mentioned in prior forum posts. When the engine is cranked, there is power to the pumps and I feel the pumps thump thumping slowing but I don't see a solid 12 volts of power, rather a fluctuating amount.
The fuel filter and pumps are all oriented correctly and there is no sign of any fuel leak at any of the newly changed components.
How would I proceed to diagnose the problem? Or am I not following the right procedure for re-starting?
