I have for sale a used ETA that is suitable for all E500s, as well as E420s with ASR.
This is the factory 000 141 94 25 part number ETA, manufactured in February 2001. That means it will have the "good" (non-biodegradable) wiring.
I will sell this ETA for $150 shipped, as-is, or $550 shipped and refurbished by Don Roden of RFC Electronics in Alabama.
$400 of the $550 cost is for Don Roden to remanufacture / refurbish it to perfect working condition. Otherwise you can use it as-is.
This ETA came out of a 1994 E420, and has the CORRECT "short" cable with smaller round connector used with the later cars, NOT the pancake connector used with 1992 and early 1993 cars. If you have a 500E or a 400E, it's likely that this ETA will NOT work for you, but you will need to check your connector underhood to be sure.
This is NOT an ETA from a W140 model with the significantly longer cable. It is 100% a proper ETA from a 124 chassis.
ETA will be shipped via US Priority Mail.
Ideal to have as a spare, or if needed as a replacement. Again, you can either pay up front to commission me to get it refurbished through Don Roden, or you can buy it for cheaper and pay Don yourself.
I connected this ETA to my car, and it DOES work in current "as-is" condition. Meaning that it connects, buzzes when power is applied, and the throttle plate turns with application of the gas pedal. I have not opened up this ETA, so I cannot guarantee that the interiors (gears, solenoids and what-not) are in perfect condition, but IT DOES WORK and the wiring is well past the biodegradable stage.
If you pay for the $550 refurbished model, then it is guaranteed and 100% tested to work, and Don Roden will stand behind it.
