w124 ASR ABS maintenance servicing frequency
yao500e
Hello fellow w124 lovers, Is this accurate to you? how often do you guys do a health check on ASR ABS system?
Maintaining the ABS (Anti-lock Braking System) and ASR (Acceleration Slip Regulation/Traction Control) on a W124 Mercedes-Benz (1985–1995) involves
addressing specific, often aging, electronic and hydraulic components that can cause the system to enter "limp mode" (limited to ~40 mph). Common issues include, but are not limited to, the OVP relay, brake light switch, wheel speed sensors, and the Electronic Throttle Actuator (ETA).
Key Maintenance & Troubleshooting Steps
  • Overvoltage Protection (OVP) Relay: The most common cause of ABS/ASR lights and poor idle. Located behind the battery, it often develops cracked solder joints on the circuit board.
  • Brake Light Switch (S9/1): A frequent failure point located under the dashboard/steering column. A faulty switch will cause ASR/BAS lights to illuminate.
  • Electronic Throttle Actuator (ETA/E-Gas): On later models (M104 engines), the wiring harness for the throttle body degrades, causing ASR failure and limp mode.
  • Wheel Speed Sensors: There are three sensors (one on each front wheel, one on the rear differential). These should be inspected for dirt, metallic shavings, or damaged wiring.
  • Hydraulic Unit & Fluid: Ensure brake fluid is changed regularly (hygroscopic) and never allow mineral oil into the system. The ABS/ASR hydraulic unit, pump, and accumulator may require inspection if the brakes feel spongy or the pump fails to activate.
  • Fuses & Relays: Check the fuses, particularly the one on top of the OVP relay, and clean the ABS relay (A 001 542 70 19).
  • Tire Size: Ensure all four tires are of the correct, matched size. Discrepancies in tire diameter can confuse the wheel speed sensors and trigger the ASR system.
Symptoms of System Failure
  • ABS/ASR Light On: The light may come on immediately or while driving.
  • Limp Mode: The car has severely reduced acceleration, often restricted to around 40 mph or 55 km/h.
  • Erratic Idling: Often associated with OVP or E-Gas failures.
Diagnostics
For ASR issues on later W124 models (e.g., 1994 E320), it is necessary to scan for diagnostic trouble codes, specifically using the 38-pin or 16-pin connector to pinpoint whether the issue is with the ABS module, throttle actuator, or a sensor.
The best thing with any mechanical component is to use it and avoid aging fluids.
To activate the ASR/ABS system, I put winter tires under the car and drove the car out of the garage. The rear-wheel drive car has been fun to drive on slippery, icy roads, where ABS and ASR are really easy to activate.
If any component is not working, it would be revealed when you use it.
As an added bonus, the heater and other heating devices were tested for functionality at -20C or even below.
Unfortunately, these luxurious health testing conditions may not be available everywhere in the world. :)
Ditt what @Efraim said. Just drive the car and change fluids on schedule. No other maintenance is needed.
Note that the OVP cube relay does not exist on 124's with M119 engines. Don't trust everything ChatGPT tells you.
:whistling2:
:whistling2:
thank you. actually, i used Google gemini 3.0 haha :)
its always a starting point for me at least. there are zero problems with my ASR and ABS but now after 35 year of this car, I just thinking about the system, the wires and connections. etc.
Boy, don't we know THAT around here, Mr. Mushroom ?!?
:mushroom:
P.S. I'm still waiting for you to provide me the URL to your [ChatGPT-hallucinated] W124performance.com forum......are you using vBulletin or XenForo for that?
well, instead of me first looking stupid bothering knowledgable members here first, I chose too look stupid to google gemini first with nuanced weird questions. lol
