Where can I buy an oil thermostat - M119.974
Dymian82
Hi, where can I buy an oil thermostat for M119.974?
Photo in the attachment
That part is not sold separately, it comes with the complete filter housing... which is NLA. You'd have to buy a complete filter housing from a car with both M119 and oil cooler.
Is your oil thermostat damaged?
:blink:
my thermostat doesn't work.
it is closed and when I heat it, it does not open.
This would be difficult to bench test, as you'd need to submerse it in liquid heated above 110°C.
Did you have problems with the engine running warm and the oil cooler thermostat not opening? Or were you just testing this for grins?
I'd re-install it and not worry about it, unless you find the oil cooler is "cold" on a hot day in summer when driving the car hard enough to get oil temp really hot.
:rugby:
Agreed, I'd carry an IR temp gauge to see if you are actually getting hot enough to warrant it's engagement and to check the temp of your oil. I only ever managed to get my oil HOT on the race track during endurance runs (2-3 hour stints)....
jono
