¿where exactly the EZL ignition module vacuum hose connects M119?
Post number 6 has been selected as best answered.
gautrique
Hi, I have a 1994 Mercedes E420 with the M119 4.2L V8. Can someone please confirm where exactly the EZL ignition module vacuum hose connects on the intake manifold? Mine is currently disconnected. Thanks!
In the back of the intake manifold there is a nipple.
See the schematic diagram in this post.
At the engine, the tube connects to the port at the rear of the intake, on the lower portion. It is difficult to access.
Any ideas on how to access this connector? Where can I trace the vacuum line to see if I can connect it somewhere in between? What other workaround would be viable?
Remove the MAF to get access to the back of the intake manifold. Normal routing of the vacuum tube is below the driver side distributor cap, then upwards and through the narrow space between the block and intake manifold.
It should follow the same path as the 8mm black tube in the photo below.
