Duh Vinci - Yes that might be an award I could win!
You guys surely know by now I don’t like to buy the easy ones!
“Nothing more expensive than a cheap W220” or something like that applies I’m quite sure.
I did intend to get “good” pics of this W220 but here goes. These are ones I snapped when it just came off the trailer home. Not washed in likely over a year BTW..... I have since washed it and it looks sooo much better without the green moss stuck in the rubber seals
Lets start with the
bad points (There are a few):
Missfire on the engine showing on Star as pretty much all cylinders. Spark plugs are likely very overdue so I’ll start with 16 of those!
RUST!! Rust bubbles on the arches and some in the trunk which will require welding (Haven’t seen under it yet either)
PO had taken apart the locking pump and lost some bits. So FUBAR. I’ll source a complete good used pump locally to get the locking working again.
Tyres are age cracked and all 4x require replacing.
Cooling system message on cluster suggests cooling fan might be bad – need to test it.
Passenger seat motor only goes half way back and stops.
No MOT as it has been stood for around 7 years. The PO (1 owner from new) woman had passed away and the car sat on the husbands drive until eventually he sold it to someone 18 months ago. He let it sit outside also then decided to sell so here I am)
The voltage is all over the place at idle and my main suspect is the alternator (Voltage regulator / brushes worn) However, I will have it fully rebuilt this week instead due to the age and mileage of it, it makes sense to do it now.
Good Points,
Original new spare wheel, complete toolkit, owners log book, 2 keys and almost full stamped service history came with it
Starts, runs drives just fine. Airmatic suspension amazingly appears to have no faults. It keeps itself up for months on end( i’m told – so far so good) and does work just fine. I can hear it let out some air when I step out for example. No faults on Star and it raises / lowers by the dash button also no issues.
A/C Works – as do all the electrical buttons inside, sunroof, heated / cooling seats and the seat adjustment front + rear. All power windows work, Parktronic etc all fine. Electronic equipment wise the car is in top order which is very important on any S Class.
PO fitted a new correct 019 heavy duty battery very recently.
All original paint on the car. Never had any paint of any kind which is great. The rust bubbles I will repair with localised paint using MB aerosol can for the basecoat + 2K aerosol clear. Paint needs a major clay, detail and buff which it will get very soon. Headlamps also need restored to remove slight yellowing on the lenses.
The seller of the car included a full set of Mahle filters and 10L of the correct spec fully synthetic oil.
So yeah – it was a great buy I think especially for the price I paid which was very good. Some TLC and fettling and this car will be a really nice driver in a few months and fit for MOT all being well. I did start a “super interior detail” today and got half of the interior done:
