I got 1500, 2000, and 3000 pads in 6 inch and a buffer with a foam pad to use for backing for edges.
The pads also have very thin padding in the back.
Whats the right procedure for this?
Do I hit it with certain grit dry before I wet sand it or do you always use water?
I get the technique on how to do it and I've done a panel using water(paint is really forgiving since its pretty hard and car had been repainted) but some areas I just cant seem to take out imperfections that easily even with 1500 grit.
Should I hit it dry?
