Another issue which I am not sure whether related or not came up. After a short drive and engine at operating temp. I switched off the engine to refuel. Then after re-start it was running very sluggish and rough like it was not running on all cylinders and there was no power. I drove to the next parking possibility and after re-start it was ok. This does not happen every time but this problem appears sometimes. Again no fault codes detected with the blink code reader after this issue.
What you describe, particularly after a short drive & switching engine off, plus no blink codes, is 99.9999999% likely to be secondary ignition issues. VERY common. Almost guaranteed there was moisture in the cap after your short drive & shutdown, which caused several cylinders to misfire. While not related to your overheating issue, adding additional ventilation slots to the cap as described in
this forum thread may cure that problem.
			From the emissions test we are reading a lean mixture on idle with practically nil CO and HC ppm after a hot run. Lambda around 1.1.
The on-off ratio using a duty cycle measurement at pin 14 on the x11/4 socket is averaging about 18%.  Does that tell you guys anything?
I don't speak duty cycle, but
@jhodg5ck might know if this means anything significant.
			In addition can the coolant flow through the heater circuit monovalve and the aux. pump have something to do with the issue? We noticed that on connections 3 & 4 of the monovalve, which we believe are the return lines from the heater, the temperature even with the heater on after a hot run was only 52 Deg. C measured with an IR thermometer.
Heater core flow should not affect cooling, assuming there is no air pocket in the system.
			@gsxr
Further to my previous post also noted the following: The E500 was parked for about 6 weeks with coolant level in the reservoir full and without being started. After starting, the warning light for low coolant came on. Checking the reservoir there was no coolant at all left in the reservoir. Empty.
No leaks detected anywhere and pressure tested the cooling system. No leaks. So am wondering if there was an air pocket in the system which after extensive parking disappeared causing all the coolant to flow from the reservoir into the radiator?
This is not good. Either the system was never properly filled before (which seems unlikely), or it mysteriously lost a significant amount of coolant. If a vacuum filler is not available, fill the block through the upper radiator hose before topping off at the reservoir. When the t-stat opened after reaching operating temp, and heater working normally indicating the heater core is filled, the system may need another ~1 quart after cooling down. You'll need to properly fill the system and then monitor the level. If you lose more coolant without explanation, something really fishy is going on.
			Today we noticed that the heating is also not working. So could there be an air pocket in the cooling/heating system causing all this?
Is there any method we can use to get rid of the air lock? Could the mono valve or aux. pump be causing an issue?
Heater not working, assuming the control panel & monovalve/duovalve are functioning, does mean an air pocket. Make sure the aux pump is working, drive the car with heater on MAX  heat, with cooling system FULLY filled (at reservoir seam when cold), and the heater should work when engine temp exceeds 80C. If not, verify the climate control (pushbutton unit), mono/duovalve, and aux pump are all working and not blocking flow into the heater core.
The valve / aux pump should not cause the overheating problems, and would only affect heater operation inside the car.
