Washer reservoir harness?
Quick4door
Good afternoon gentlemen, my 92 400 E is having an issue with the wiring harness for the washer, reservoir, level sensor, and the coolant reservoir sensor, I’m not sure if this is a sub harness, or part of the engine harness. (The engine harness was replaced prior to my purchase, but I have rebuilt the lower engine harness as well). Not sure what the best repair is, whether to just replace this sub harness, rebuild it, or simply repair parts of the fallen apart. Does anyone have any part numbers or suggestions?? Tia
Good afternoon gentlemen, my 92 400 E is having an issue with the wiring harness for the washer, reservoir, level sensor, and the coolant reservoir sensor, I’m not sure if this is a sub harness....
Can you elaborate on the issue(s)? I think that is part of the body harness, which is NLA and not practical to replace (and, almost never needs replacement if undamaged).
The insulation is flaking off, and the two connectors have broken due to age. If that’s the case, I’ll just grab something from the salvage yard next time I’m there and replace the two ends.
