A Happy and Healthy New Year to all of you! Arrived back from Germany and slowly but surely some of the AMG parts are starting to accumulate. Received the NOS rear spring and the NOS front spring and will be approaching two companies to get them replicated (one company in the Netherlands and one here in the U.S.) to complete the set. Also ended up buying two used AMG hydro legs for the rear. Now for the wild goose chase of finding the corresponding HWA front dampers….
My car had been sitting since August and when I started it, it quickly developed the dreaded misfire, so I deinstalled the rotor caps to check for moisture and the right bank was wet. The left bank was bone dry. Wiped the right bank dry, put it back together and now it’s running again. The ignition system really is the Achilles heel of these engines
While at it, I also put on the unmuffled M117 zoom tubes and it actually makes a difference as the intake noise is now a bit more audible, which I really like.
Still shooting for end of 2023 to get the entire 6 Liter saga closed out and in the meantime decided to sell my RIALS to a forum member, as I want to have a bone stock look once the new engine goes in.
