Yeah, I hate it when that happens. You're stuck between sprinting to that light at the end of the tunnel ("once this is done, I'll be all set"), the wallet and fun drain, the time spent at the shop (I'm in that place with the Allroad right now, just back from the shop, knowing it has to go again when they have time), and the nagging feeling that it'll never, ever be set.I’m getting increasingly annoyed with the unexpected outflow of money to fix ever new issues that rear their head just when I thought I was getting there... I will just give the whole thing a bit of a rest. Too much shop time, too little wheel time and way too much open wallet surgery![]()
Parts Are Gone. Everything is a wild goose chase. And like the E5E, tons of 4.2 specific parts on this car. Almost anything 4.2 specific is NLA.How is the spares situation with the Allroad, @maw1124? Are parts still easily available or do you have to wild goose chase parts all the time?
@TimLThanks Terry and Drew, you guys have a lot more experience than me, so I trust your opinion. Just was shocked how crusty those E500 calipers from the wrecking yard were when I opened the box![]()
Thank you for the info Dave. Considering how bad the calipers look makes me wonder about the rest of that car. Must have been neglected and put away wetThey are crusty externally, but that will clean up nicely with media blasting. The concern is if the pistons move smoothly... they may be fine, but the rebuilder will verify. If the bores are not corroded (which is unlikely) they should be fine to rebuild.
Here you go @maw1124, two highway pulls, accelerating in gear with everything stock, except for the Fließen front end with cats.A stock rear box with more flow might be an interesting sound. I always felt like the cats were what clamped down the stock exhaust. I think @TimL has probably stumbled upon a pretty natural, factory component preserving solution. Would love to hear clips.
Wow, that is a flieben front section w airtek catalysts and stock resonator and rear exhaust? Was this recorded using ample throttle? It sounds GREAT and I suppose it is still nearly silent at light / part throttle.Here you go @maw1124, two highway pulls, accelerating in gear with everything stock, except for the Fließen front end with cats.
Sounds like what stock should have been to me. Had they all sounded like this no one would have touched their exhausts, LOL.Here you go @maw1124, two highway pulls, accelerating in gear with everything stock, except for the Fließen front end with cats.
@TimL,
Sorry to say I find that sound disappointing. It sounds to harsh to me in the front of the cabin. I can see why you are removing it for the stock Headpipes and CATs.
Maybe it’s just me but I prefer to hear the CAT BACK sound behind me and the car.
The brake refurb place here in the Seattle area (Goldline Brakes) just notified me that they are done with resuscitating the crusty e500 320mm calipers I had sent them. They actually had them sent out for plating (instead of painting or powder coating), as I had asked them to match the finish of the new 300mm rear calipers that I had just purchased from MB.Thanks Terry and Drew, you guys have a lot more experience than me, so I trust your opinion. Just was shocked how crusty those E500 calipers from the wrecking yard were when I opened the box![]()
Tim, the washer fluid reservoir itself rarely, if ever, leaks. What I've found to be the leak point is most often the grommet for the pumps, and second most common (and mis-diagnosed) is leaking pumps. I chased a couple of these leaks and couldn't figure out why new grommets didn't cure it, until I discovered that old pumps can leak from the pump body. If your pumps are original, check this out first...
- wiper fluid tank - had a new tank installed not even 18 months ago to replace the original discolored one only to discover that the new tank started leaking recently so this is the second attempt
+1 w/ gsxr in regards to the pumps leaking at the seals. I kept finding water under the right front end of the car. It turned out to be the rubber grommets at the pumps. I changed out the pumps and the seals about 10 years ago.Tim, the washer fluid reservoir itself rarely, if ever, leaks. What I've found to be the leak point is most often the grommet for the pumps, and second most common (and mis-diagnosed) is leaking pumps. I chased a couple of these leaks and couldn't figure out why new grommets didn't cure it, until I discovered that old pumps can leak from the pump body. If your pumps are original, check this out first...
@maw1124, the front section without cat is blocked for the U.S. market so you can’t order it through the U.S. dealership. I walked up to the local MB dealer here in Marburg and ordered it. Shipping will be a bit of a mess, as I learned when trying to ship the low mileage cat section I bought in Germany two months ago. Seller of that unit doesn’t seem to have much international shipping experience so it’s taking a whileThat’s a great haul! Did you need to be physically in Europe to order theeuronon-catted Section 1? I don’t see that from here.
FWIW, ‘92 cars not in CA don’t need cats at all, quite frankly, as I learned when I did my exhaust. FL guys were like “why are you putting cats in?? You won’t get a CEL and checks aren’t required.” Because I’m a tree hugger. Please put them in. I don’t want to smell a bunch of gas fumes and since I installed race cats, the smell is already strong enough. So a factory catless Section 1 could let me install cats further downstream to finalize the clean.
Hmmm. The last possibility is a poor connection between the hoses and the pump. The tank itself cannot leak unless there is a crack or hole in it, and I've never heard of that happening over the past 25 years reading MB forums. Especially not a brand new tank.Thank you for the advice! Alas, the grommets and pumps were all changed to new at the same time as the tank![]()
Tim, is that from fender lip to wheel center (which eliminates tire diameter variance)? High 13's is just about perfect, IMO...Fender gap on the stock setup with the E60 replica springs is 13.8” in the front and 13.9” in the back
The summer tire selection for the stock wheels is next to none, so I wanted to see if I could make a 225/50/R16 tire work. I ordered a single Kumho Ecsta V730 and had it installed on my spare wheel and installed on the car.
As much as I wanted it to work, I just can’t get over the fender gap that the shorter sidewall leaves
I will look into getting tires over here from Europe but I don’t think that is an article that customs allows to enter.
I might talk myself into another 18” wheel but I just hate the weight 18” wheels add. Yeah NEEZ, etc. just not happy that you have zero tire choice anymore when it comes to the stock wheels
1/4! That's cray-cray. You're making me want to check into Grundy... then I remember their weasel wording about not being able to drive your car when/where you want (link). Last I checked Grundy has a hard "no" for any racing use, which never made sense to me... Hagerty's policy did make sense (the vehicle is covered anywhere except ON the track, link).Grundy is 1/4th of the price of Hagerty. ... Hagerty ... are smoking crack cocaine
Sorry if I missed something ---- are you 100% against using ATE or Zimmerman rotors? If not and you want to keep everything MB branded, I understand. You are the ne plus ultra of originality!Brake rotors are handed and one side is NLA, so I’ll have to drive around with two left hand rotors which means that the rotor vanes on the right hand side will be incorrect but that shouldn’t be too big of a deal. Just another NLA defeat that MB hands people
I guess keeping the cars running with genuine parts is successively becoming more and more challenging
FWIW I just bought rotors for my w210 and I was somewhat disappointed to discover this:For reference... the 320 rotors are 129-421-17-12 left, 129-421-18-12 right.
Zimmerpersons appear to be NLA everywhere, but the rotors are still available from Ate and in stock at FCP/RME/AHAZ for $80-$100 each. FCP claims they are made in Grrmany. I don't know who the OEM is for the Genuine rotors.
Ugh, guess I should get a spare pair (not square) before Ate changes their mind. I wish there was an affordable source to get them cryo treated, shipping heavy rotors both ways to a freezer isn't cheap. And, the places that sell pre-frozen rotors typically sell cheap Chinese rotors, not name-brand stuff.
