Where did you find those ZDDP numbers? They look incorrect. And, it shows an old version (CJ-4) which did have higher levels than current CK-4 spec, but still only in the 900-1200 range... never 1300-1900. Click here to view the CJ-4 test data from years ago, type "Mobil" to filter.I have been running Mobil Delvac 1300 super 15w-40 in my 92 500E with 134k miles, for the past 2 years. .... However, after reading through the oil discussions on here, my concern is the high ZDDP levels with this oil on the m119 and the catalyst. What are your thoughts on this?
The current CK-4 stuff that's been available since about 2017 has ZDDP levels around 800-900. Any Delvac 1300 Super you'd have purchased in the past 5+ years would be CK-4 rated with low ZDDP.
Furthermore, what are your thoughts on running this weight in the winter in [Atlanta]?
The factory Mercedes viscosity chart says 15W-40 is acceptable to temps a bit below freezing, so you should be ok running that year-round near Atlanta.
I never would have connected those two dots!
