WANTED Headlight wiper blades for 93 500E.
MK500
93 500E, 95 E320 Cabriolet , 95 S600 Coupe (sold)
Looking for a pair of headlight wiper blades.
Appreciate any and all suggestions.
Do you want USA spec wipers for USA headlights?
Or Euro wipers for Euro lights?
The wiper arms, blades, motors, and trim panels are all completely different on pre-facelift cars (500E).
:124:
You’ll have to help me here.
I have a single owner USA 93 500 e. with full documentation.
i don’t recall seeing any headlight modifications in the documentation.
the headlights do shine low on the road in low beams and have a raised notch on the glass.
A picture is worth a thousand words...if you want a definitive answer, post a picture of the front of your car. :)
Raised notch means it’s US lights, I’d assume. Do your lights and wipers look like the attached?
Those are the USA lights.
Do you just need the rubber insert refilled? The blade itself (holder+rubber) is NLA, but it's possible to refill them with fresh rubber from a new larger refill.
Will give them a try!
Many thanks!
Works on a 95 E320 possibly as well?
Put the Volvos on my 93 500e and they clip in fine but are a little long and go past the crack between the lens and glass frame.
Still have to check about actual operational effectiveness and will report. Can’t cut to fit b/c the notch for the metal stabilization strips is still just beyond the separation.
If they work fine they are a very good and inexpensive and available replacement.
