WANTED Intake Tubes From M119 to fit M113 (will buy & advices are also allowed :)
Merso_AMG
Hello Dear Friends.
Have some trouble here, may somebody can help.
I installed M113 Kompressor Intake on my N/A M113 Engine.
Everything fits with a little modifications, but i have trouble with the tubes, that allow air boxes to receive a fresh air.
Here i am attaching the image of my Setup. (I used some flex tubes, but want to reach more factory look).
Car is W210. Yep i know that W210 E55 has different Radiator, and 2 snorkels, that's no way for me, because i don't want to spend extra 300+ Euros for China made Valeo radiator...
W210 E430 has 1 snorkel for fresh air, passenger side of the radiator. I saw several setups online, where Some W210's with M119 engines are using 2 dual intakes with the tubes i am looking for... W210 M119 also comes with 1 snorkel setup (420, 50)... Doesn't matter.
Here they are, you can see the images.
My question is following: Can anyone tell the part numbers of intake tubes that will work with my setup?
I also found the tubes from W210 E50 AMG, but they are very expensive...
Can any expert here help?
Regards
David
TerryA
M113 is my car. I have been searching for all day and found that Red W210 Renntech is running A119 094 73 82 on the passenger and Black Renntech is Running A113 094 12 82 on passenger as well, but can't find which they run on driver side. (This side is main issue for me). Here is also M119 Lorinser which is also equipped with A119 094 73 82 on the passenger side, but driver? (Looks like Left intake tube is also cut to fit)...
Most of these tubes are still offered from Mercedes (German Stock), but i'd like to know which one to order. I already tried to use W211 E500/55 intake tubes and they don't fit.
Came across this on one of my E55s. I couldn't figure out the part numbers others used and was convinced there wasn't a factory solution so ended up cutting 1130942182 and 1130942282.
Here is another Carlsson CM62
what are that tubes, searching all day 😠
Right from W140 S500 M119 - A1405200104 about 25 Euros from Germany Mercedes!
Left from R129 SL500 M119 - A1190940082 About 75 Euros from Europe (Different Online Sources - Very rare item)!
MB Classic shows A1190940082 as NLA, which is probably why it was rare / hard to locate:
MKB HEADERS;
SLK 55 EVO Camshafts;
Full Stainless Steel Catless Exhaust System;
No way to save that 1 tube 4.3 intake setup -> Switched to M113K intake!
