Hi guys,
I had been chasing a misfire on my 93' 500E for a month. I had replaced spark plugs, caps, rotors, and insulators behind the rotors thinking it might have been a moisture build up behind the cap. Car ran fine cold, BUT would misfire as soon as it reached operating temperature.
Then, I started focusing on the suppressors that fit over the spark plugs and the terminals that fit over the cap. Measured each wire for 2,000 ohms of resistance +-10%. Number 8 wire tested a little out of range, so I replaced the terminal and suppressor. Still, I had a misfire after warm up. The wires were a mix of Bremi terminals and Karlyn suppressors. I was not impressed with any of them.
Finally replaced all 8 plug and both coil wires with new Beru wires made in France. Dave sent me this link and I am very happy to report that my problem is solved. Select the wires that are specifically for YOUR YEAR MODEL because they are cut to the proper lengths based on year model. 1992-1993 500E, OR 1994 E500.
If you decide to do this job, Wurth Rubber Care will be your savior and make life very easy when adjusting wires and connecting them to plugs and caps.
Many thanks to Dave for his excellent pictures and link to these wires.
Also, many thanks to Jono as he told me about Rubber Care and wire numbers to the corresponding cylinders that are listed in the plastic tracks. It would be difficult to do this job without those numbers.
This was my first time to replace wires and it took me 4 hours to make mine look like Dave's pictures, but I think I could do the job in about 2 hrs. now. I ordered wire markers and clipped them onto the wires BEFORE I started the job by measuring each wire first and labeling them. Made it easier to keep up with the wires.
Link to PG Beru wires:
W0133-1599712 | Partsgeek.com
Wurth Rubber Care:
www.autogeek.net
After a few thousand miles, these wire markers will expand due to heat and slip around on the wires a bit, but none have come OFF the wires.
Shrink wrap markers should be used to alleviate the slipping problem.
Wire markers:
This photo shows the correct wire routing:
http://www.w124performance.com/images/M119/EZL/wires/M119_ignition_wires5.jpg
More pictures here:
Index of /images/M119/EZL/wires
Wurth Rubber Care:
BLACKFIRE Car Care Pro Detailing & Polish Products - Autogeek
Use the same automotive detailing products as the professionals by ordering Blackfire car wash, ceramic polish, wheel kits, tools and other car care supplies.
Wire markers:
Amazon.com: Taylor Cable 41060 Clip-On Wire Marker Kit: Automotive
Buy Taylor Cable 41060 Clip-On Wire Marker Kit: Spark Plugs - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
More pictures here:
