W124 e320 wheel recommendations
@alabbasi,
I believe these pics must be in photobox by an outside vendor. Gerry just talked about this type of pic. Older ones can’t be accessed.
Check w/ GerryVS
UGH. No, those photos were not on Photobucket. They were uploaded directly to the forum. I should still have the photos, I can re-upload if xfadmin cannot restore them. I'm worried about this being a larger issue with other images missing/corrupted on the site, that we may not have found yet.
:run:
Yes, 7.5 ET36 is fine. Same fender lip roll / fender spacers / etc, and a 225/45 tire.
Be careful, there are aftermarket copies of this wheel that use cone seat bolts. Don't mix them up. I have a set of these, two OE, two aftermarket, and have to be careful to use the right bolts. This wasn't on purpose, the wheels came on a car I bought.
:roadrunner:
ill try to find this model wheels in OEM
Sample photo of our E420 with 16x7.0 CLK wheels from a W208.
Stock springs, front "blue" (tall) spring cut 1/4 coil, 1 pt pad. Rear "red" (short) spring, 1 pt pad. Ride height is 14.25" front and rear with a full tank of gas. I don't recommend going much lower for a daily driver that sees real world roads with potholes and speed bumps. When the gap above the tire starts to disappear, IMO it's too low, and suspension travel starts nearing zero as well. Might look cool that low, but it will ride like crap.
:grouphug:
Late 90s CLK wheels are a popular choice. I have them on my wagon. Here's an example I found from a quick eBay search:
Those are my Favourite for these cars. I have a set on both my E420 and 300CE
This will work fine, but will require rolling the fender lips front & rear, plus fender spacers, etc etc. Definitely get a rounded profile rear tire.
Keep in mind the 7.5" front Evo wheels will not clear brake calipers 300mm or larger.
What 17 inch wheels clear the silver arrow brake setup?
Most Mercedes and AMG wheels 17" and larger diameter clear the SA front calipers fine, but there are some exceptions, like the 7.5"-wide Evo wheels for example.
The problem is when the spokes contact the face of the caliper. For any aftermarket wheel 17"+, it will be a trial-and-error fit...
Hello, I like to jump on active topics rather than opening new one.
My monoblocks are bad and I need a new set of wheels to get the car out and work on it. I did find some deals locally just wanted to see what would work best. Also, for permanent wheels, what is the best option out of the box new? Like off the shelf. 18” looks good and I would prefer that size.
Also, with the wheels I found locally, do I need new bolts? Which ones?
you should list the wheel sizes tgat you found locally
very few people will recomend 18’s,
is this for 500e or regular e320?
I have a E500 and I’m using monoblocks from E55
Those star pattern are same size as monoblocks.
What's wrong with the Monoblocks?
Are the 'star pattern' wheels the same width AND offset (ET number)?
For the bolts, it depends if the wheels are aftermarket or MB / AMG. And if factory, you'll need the part number from the back of the wheel. A lot of newer wheels (model year 2000-up) are from chassis with M14 bolts, and if those are installed on a W124, they require special hybrid M12 bolts with R14 ball seat. AND, the length may be different too.
You'll save yourself some headache going with a wheel that is known to fit properly. Guessing you don't want to shell out for another set of Monos since they're quite spendy these days, at least for refurbished sets in mint condition.
I burned myself with monos, I would pay top $ for a good set, but then I might get in the same position as I am right now, they all roadforce balance at the end of acceptable limit. Still vibrating at high speed. That’s why I need any not repaired set that will work for the moment and in time I would like a replica - reproduced or whatever NEW wheels.
Thanks for the info on the bolts, it looks like I’ll skip the used set and drive my mono until I get a new set.
I’ll go ahead and read all the forum to see what would be the best fit and what’s out there.
Ps I was thinking to get custom made wheels, will see if my budget allows that )
You probably don't want to invest any more time or $$$ into the current set of vibrating Monos, but... it may be worth checking runout (radial + axial) on all 4 to see if any are bent enough to warrant straightening. If the wheels are straight enough (say, absolute limit of 0.80mm out in any direction, details here) then try to find a tire shop willing to PROPERLY balance. That means in addition to Road Force "force matching", and dynamic balancing to <5g, also performing a static balance afterwards - read this post for more info. If there's still vibration after all that, you may have 1 or more defective tires.
New custom wheels are definitely worth looking into, because you can specify the exact width & offsets, and pick the exact style you want as well. Plan on $3k-$4k ballpark for a set. If you like the look of Evos and want 18's, I would seriously consider NEEZ out of Japan. With the favorable exchange rates I think these were in the $3k range delivered. Anyone know if tariffs are still a thing on auto parts imported to USA these days?
:blower:
If the tire mfr spec sheet approves that width for that tire, yes. I think 8.5 might be near the max width wheel for a 225/45? This will be a bit "stretched".
:burnout:
i dont have tire mfr spec sheet, but from what i read on google it says that is okey
here is some examples
Look up the tire you plan to use on Tire Rack, check the specs tab.
Random Michelin shown below, says 8.5" is max wheel width for that size tire.
