OWNER JC220
    Votes: 2 22.2%
    Votes: 7 77.8%
  • Total voters
    9
  • Poll closed .
I keep forgetting the 201.034 had SLS as standard equipment. :doh:
You are right, Joe, if parked for extended periods (many months, or years) the SLS rear end can sag like this. A bit concerning that a ~£250k car may not have had the engine running much prior to listing - or, that the SLS has problems.
I don't think the fuel distributor was working at all in my 190E. I suspect it may have been running on the cold start valve.
Look at the green deposits that came out of the inlet filter screen alone on the KE fuel distributor
I am curious what the insides will look like when I dismantle the fuel distributor for proper cleaning and the rebuild kit.
:update:
The 300E intake boot does fit a 190E 2.5-16 but not without slightly enlarging the side hole for the small tube to connect without stretching the rubber boot too much. (I used an air die grinder)
20250827_192056.jpg20250827_192037.jpg20250827_192030.jpg20250827_191801.jpg20250827_191700.jpg
Back together now, less the metering head which I will start stripping down next.
(It will get a full restoration later, this is just about getting the car running properly)
I got to dismantling the old fuel pumps tonight.
I tested them and one pump was dead and pulling current/ short circuit. So what I was hearing was just one pump running and I'm not sure if it was good either.
New genuine bosch pumps should be here tomorrow. I am tempted to try ultrasonic cleaning the fuel distributor complete and trying the car again over the weekend to see if the injection system works this time. I won't fit the new fuel injectors just yet until some fresh fuel flushes through the system incase tiny debris goes into the new injectors.
I also tested the throttle body potentiometer and its working OK. So ill see how the car behaves over the weekend if the pumps arrive and I get it back together for a test run.
I hope the whole mistake reverse thing was an overplayed joke there!
To select reverse you have to lift the selector up. So its not really something I see as an issue. The good thing is all my other cars are automatic so I shouldn't mix it up once im driving the 190 for a while.
Obviously the purpose of a dog leg manual transmission is to keep 2nd and 3rd gears on the same throw which are the most used gears in racing. So ill have to test that out on some windy roads along with the lap timer :gsxracer:
Another 190 update -
This evening I got a couple hours of dry weather and fitted the new injectors & fuel pumps. I ultrasonic cleaned the fuel distributor and that worked great the needle now moves freely unlike before. No sign of any debris in the ports at all after cleaning.
There are small fuel filters on each injector line output so I removed them before ultrasonic cleaning and cleaned them too. That made me comfortable to go ahead and fit the new injectors knowing the lines are filtered anyway.
The car started right up and ran very nicely albeit I can still only run the car for less than a minute at a time due to the head freeze plug leak not allowing the engine to hold coolant. The engine sounds healthy and zero smoke from the exhaust. No knocks or strange noises it runs very well :)
I think this is a great car, it was sitting too long and down on its luck but anything I check has been better than I expected.
So that gives me enough confidence that the engine can stay in for the "rolling restoration" stages so next job will be to tackle exhuast manifold removal which will be tricky to access and rusty bolts so ill be using my inductor tool to heat them. Then replace the freeze plug and pressure test the coolant system before the manifold would go back on.
Does anyone know what the 2x sensors are in the air cleaner box of the 2.5-16's please? One must be air temperature but I am not sure what this larger 3 pin sensor does?
It is disconnected at the moment until a new air filter arrives in a few days. The old air filter was very manky and I couldn't locate a new one in UK! It had to come from Germany and I dont want to refit the filthy one even for a few days.
Update on the 190E,
I flushed the fuel system and changed the fuel filter. I cleaned all of the engine electrical connectors. Alot of them had signs of corrosion. It primed the fuel pumps and built pressure no problems no leaks. Then I got the oil filter today. I changed the oil and cranked it over without the spark plugs until I it built oil pressure.
Then it was time for a first startup attempt:
I can't run it for long until I replace the freeze plug in the cylinder head which means exhaust manifold must come off. But it did move under its own power briefly today for the first time in around 14 years. The fuel injection system isnt too happy ill have to look into that.
The work is only really getting started but there is a significant improvement now when starting up the car VS the first start above:
I have ordered one of these I will show how it works when it gets here Mercedes KE-Jetronic tester / diagnostics device | eBay UK
Whilst I have blink readers and 2x full MB laptop setups the KE Jetronic doesnt support anything other than blink reading. So this device does the code reading for you and also displays the mixture % if the car has a lambda sensor. (Or still code reading even if no lambda fitted)
I am not sure if this 2.5-16 has a lambda sensor. I haven't got under it to check, I will soon. The presence of a throttle position sensor suggests it "should" have a lambda sensor on the exhaust and if it does I will replace it as like everything else on this car its probably original. (No bad thing really, how many of these cars are still almost exactly as they left the factory)
Without watching the video... With a dwell meter you can check the function of the cis-e very well and "read out fault codes too". If the video covers that good... But search, there a lists of what certain fixed outputs mean in regards to faults. Also the idle and partial load mixture can be adjusted with the dwell meter quite well.
@JC220,
Joe, You’ve become a Movie Star! It’s nice to put a face to your name. I didn’t realize you were such a young guy. I’m surprised you have so much talent for your age but it really nice to see young people carrying on with your enthusiasm. I’ve been a fan of yours for a very long time and often look back at your threads.
I for one will be looking forward to your new videos.:thumbsup2:
Take Care My Friend:)
@JC220,
Thank you very much for your kind comments Terry, much appreciated
Second video now up - cut it at 40 mins. Maybe I rambled too much and should make them shorter?
I have also started a tool shorts series - 1st one here
I got the battery tray welding all complete and in primer as of today. Phew, what a PITA that was - so little room to work.
Front suspension all removed and dismantled ready for restoration
I am making new Kunifer brake lines up front first. I got ral 6006 satin paint custom mixed so they will look exactly as original when done
15-20 mins is optimal for YouTube videos. That said, I have long been watching all YT vids at 1.5 speed for time efficiency. You can blow through a 40 min. video in significantly less time. 🤨
Thanks for the feedback Gerry, yes Ill try to to target say max 20 mins per video going forward.
I am also wondering should videos be more targetted than progress videos. For example, I am restoring and rebuilding the brake calipers. So instead of breaking that process accross 2 or 3 general progress videos, better to produce one video showing that complete process?
Thanks for posting, just so you are aware, your uploads are now appearing as suggestions in my YT feed outside of this site.
I must confess to not having finished watching all your uploads, mainly because I don’t own the vehicle in question and therefore don’t have a requirement for a deep dive. I’m of course very interested in the overall subject matter you are covering which is repairing and restoring an older MB car and will be able to return anytime in the future if I need further information.
I think the question for you might be what are your aims for the content you are creating?
Are you looking to document what you are achieving primarily for personal satisfaction.
Are you hoping to provide instructional media for other owners to refer to on their own cars.
Finally, are you seeking to monetise the effort you are putting in?
I'm not a content creator nor do I play one on TV streaming, but... since you likely have all the footage to play with, why not both? Split up into shorter videos, but also have a single full-length vid?
In general I like videos that are short, to the point, and have minimal fluff or wasted time. I'm running out of minutes. A new addendum to "Nobody, ever, on their deathbed said 'Gee, I sure wish I spent more time in the office!' is '...wish I had spent more time watching YouTube!'.
:oldster:
In short - all of the above!
One of my brothers was encouraging me to share my hobby on you tube and bought me the go pro for christmas.
As a personal resource / log the likes of this owners thread is very useful to look back on. I do the work anyway as a hobby so its easy enough to record as I go and doesnt require any additional time or effort to speak of.
I do want content to be informative and helpful to viewers. To hear their opinions and learn more. I like Edd China's type of content if that describes my long term goal better content wise.
Montisation - yes eventually would be nice. But never as a business as I have a full time profression that I am very good at and get paid well for.
Just a small % back towards more tools and parts to feed my fleet would be a nice thought. But that is years away in reality.
Thanks Dave you are right and this feedback is a great help.
If I want to stand out then ill need to do more shorts etc. At the same time ill never stoop to the lows that some you tubers do for views! (Unrelated sponsors, dumbest channel sayings etc and cringe thumbnails)
Even if I say so myself, through years of hard work my expertise in these cars is there. I concentrate too much in detail by my nature so I need to work on scaling that back for video purposes. I think I could have and should have started years ago but ill keep posting now ive started and see does it pick up views.
Next upload this weekend will be a max 20 mins full tutorial on DIY brake caliper refurbishment :banana1:
@JC220,
Joe, I use compressed air to blow out the pistons. Put the caliper in a vise. Stuff a shop rag in front of the piston to stop it from hitting the other side of the caliper and apply compressed air to the bleed nipple hole. Piston pops out in seconds. Try it next time.
@JC220,
Hi Terry, thanks for that I had talked about it but cut the video away down in size. Compressed air doesnt work all of the time due to gummed up / rusted parts. Especially here in our climate! Brake fluid can spray out too.
The grease gun method works great, is very controlled and powerful. It will shift seized pistons. And as soon as the piston is out the fluid pressure drops so quite safe.
I guess I’ve never had calipers in that bad of condition. My worst fear is breaking off those damed bleed screws. I liked your method of welding a nut to it. It worked great!
Yes the screw breaking off was not ideal! I use that welder + nut technique for all broken bolts it works great! You get a proper hold on whats left and it puts alot of heat down which does help removal massively
Joe, how do you like the Valeo pads? I didn't even know they made brake pads!
They seem decent visually at least Dave! I got them from autodoc they have a large selection of brands. For this 2.5-16 there is not a great # of brands available. Valeo parts are decent from my experience on their wiper blades etc
It'll be later this year until I drive the car and test them if I get this mountain of work done! In a way videoing it may help to keep me focused on finishing a project and not hopping between cars :jono:
Looks like those are the 284x22 front brakes, same as most early 124 chassis. And yes, there is not a large selection of pads available for that application. However, I recently installed a set of EBC Greenstuff pads on my 300D with the same front brakes, and have been quite impressed. Really good pedal feel, high/firm pedal, good modulation, good braking power. Bit dusty, but that's the tradeoff for brakes which actually work right. I was just happy Ate rotors were still available, made in Germany. The OE MB rotors are NLA.
EBC pads are expensive here in the colonies though, maybe they are cheaper in the homeland!
You reminded me to check the discs I got are correct size Dave! Comparing to the old ones these Hella discs are correct which is good, I can throw the old discs away now
I need to catch up on my editing and uploads. But lots of work continues on the 16V. Major rust repairs up front completed. Arches POR15, epoxy primed, satin black sprayed and waxoyl treated
Front suspension parts restored. Zinc plated at home or renewed and laid out before final fitment
Front going back together
Looks amazing, Joe! I assume you know the strut dust boot should attach up top to the mount, not on the strut "tie wrap"...
Thanks Dave, I missed that one! They are normally sitting down on the tie when I get to them :rugby:
Do they just slip around the top mount and no other fixings or tie wraps required?
Correct! There's a lip on the lower edge of the mount that the boot will slip over (requires some fiddling).
The lower edge of the boot should not slip over the tie wrap, the boot should "float" above the tie wrap at full extension. Should look like this normally:
:roadrunner:
Sorted now :jono:
I am making new brake lines up front and in a few days it will be back on its wheels but not for long as the next stage will start right away which is the weld repairs to jacking points.
