Roadtrip to northern Germany and southern Denmark / Sweden
t-1 - Tomorrow we have lift-off
Oil, Brakefluid and AC Refill done. Still some small things to do before we head of tomorrow:
- AC controller is acting strange
- Left speaker on Radio
- Fuelgauge is living its one life
- Antenna does not want to come out properly
Did 800km today. Car is running great. Initially the kick down would not work, but with every km it seems to be getting more normal again. Photo is courtesy of my passenger.
In stock mode, the needle actually goes slightly beyond 260km/h. The challenge ist that now days it is very difficult to drive safely at that speed (too much traffic and too many people pulling out without looking), so no real need to remove it. I wish it was different.....
Trip is going well, but some technical gremlins I need to address:
- AC - while it is running and keeping us fresh, the controls do act up a bid wird. I assume it is that some temp sensors don’t align
- I had an on and off failure of one of the turning lights. It is corrosion in the socket
- I found a strange nylon wire like 1mm thick under the seat. Not sure yet what it is for
- kick-down only goes down one gear in S-mode
- the alarm system is showing a continuous red light and not functioning
- fuel gauge sensor needs refurbishing
- front left speaker needed replacement
- the rubber cap for the antenna dissolved
Overall not bad for a poor car that was not moved the last 14 years and now did 1600km in one week
I have the control panels for both the dual zone and the automatic clima if you suspect that, it's pretty easy to replace if you want to. Working a/c is a must now with the temps here in Sweden around 30C/86F. Scorchio!!
Thx for the offer Thomas, but it seems with every km more, more functions are recovering. So currently AC works perfect
