I recently had a brand-new, out of the box, Bosch cap that was defective. Looked perfect - still does. Measured fine via ohm meter. Only caused an intermittent misfire at hot idle, zero issue under load, at WOT, or above 2k. Drove me absolutely batty trying to diagnose it and took about 5 hours total time. Don't think I will be buying Bosch caps again, for $90 each I expect new ones to actually, you know, WORK.
Dunno what the best alternate brand is, or if OE (likely Bosch as well) would be any better kwality.
Bosch quality control is hit and miss lately with their "Global" manufacturing plants.
Beru caps don't have the orange with black cover set up
Bremi is still made in Germany and I have 3 years on mine (cap/rotor set.)
Autohaus AZ has both for the same money ($221),
but a seller on e-bay that I can recommend has the cap/rotor set for $199 total shipped
Mine look good still, but I just ordered a back up set in case this guy runs out at some point.
Best price I've seen over the last few years.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&vxp=mtr&item=221460885179
it does sound strange to me with the venting- are you installing them on a low humidity day?
Why did you go with stainless steel bolts? They are usually softer and can gale more than the plated allen bolts(correctly called SHCS - socket head cap screws).
At least you probably have a better selection available metric fasteners than we do in the USA!
Michael
Arnt, are your SS bolts 3mm socket head, or 4mm socket head?
The worst part about the stock rotor bolts is the stupid 3mm socket head!!!
They require new bracket for installation with part code "06" instead of "04".
Hey guys as of right now there is a sale from AIautoparts for bremi caps and rotors. They require new bracket for installation with part code "06" instead of "04". 179$!! Steal! They usually have them for 199! Just ordered mine last night!
If your cap n rotor are recently new the bracket should be updated , in the ebay description the seller describes what they mean by updated bracket , be back later to explain more to u
Can anyone please be more specific on this point. Is there a separate part I need to buy to make this set work? If so, what is the part number? TIA.
New version, note the knurled threaded inserts. The old brackets had hex nuts.
This is an example of the early mount, it's a M103 but it shows the pressed in hex nuts
same as the early M119 0440 part
Hello Guest !
