  • ATTENTION
    Thank you,
    Management
FOR SALE 1993 500E, Arctic White/Blue, 177kkm, €49k (Vienna, Austria)
036
Found on Facebook
Pleas move it to proper location
VIN = WDB1240361B978997
Datacard: https://www.lastvin.com/vin/Pgkjo2NLjrjdVa4qZ
Google translation:
Austrian car, service book, properly cared for and beautiful, special leather, sliding / lifting roof, automatic air conditioning, full leather interior, seat heating, auxiliary heating, Becker navigation radio, front seats electrically adjustable with memory, mirror automatically dimmable, without type designation, steering column electrically adjustable, Roller blind for rear window, burglar alarm and anti-theft alarm system, front armrest, fire extinguisher, engine and gearbox were replaced after approx. 90,000 km, new tires, new service, complete documentation from new purchase, new catalytic converter, new service, oldtimer insurance possible
ID 1414
MODEL YEAR 1993
KM 176.700
COLOR arcticweiß
INTERIOR dunkelblau
PRICE IN EUR 48.700
  • WDB1240361B978997.pdf
Note this car is a 500E, pre-facelift, that had a facelift treatment; as it does not have code 859 in the datacard (indicating "early" facelift prior to the VIN break). And, all facelift cars were Polar White (149), not Arctic White (147). It should have come from the factory with monochrome paint as well, not gray lowers.
Looks really nice otherwise, and has the auxiliary heater. First time I've ever seen the REST button on an 036, I wonder if that is functional, and if it was added post-delivery? Odd that the right-most warning indicator is illuminated, this should be blank on non-USA vehicles. Maybe the wrong bulb wire was inserted into this position.
I can see why an Austrian car would have the rest button installed perhaps as a Dealer Installed Option, along with the phone holder, etc. Nice car. @gsxr answered all my other questions about year, front fascia and lowers.
maw, according to the EPC, the REST function was never offered on any 034/036. Prior to this car, I've never seen one with that button. Which is why I was curious about it.
In theory a 6-cyl REST harness could be added but I don't know if there's any technical limitations. I always wanted to try this but was never able to obtain the necessary harness (124-440-36-09, NLA for over a decade).
And what is this button doing? Double horn is serial, not an option... what s this?
it‘s the MB abbreviation for the German word “Restwärmenutzung” meaning you can heat the car even when switched off with the residual heat of the engine (I believe for a max period of 90 min).
Correct! With the engine off, it runs the auxiliary coolant pump, and blower on low speed, maintaining heat for 15 mins max (click here for a functional description document). In cold climates this is really nice, you can turn this on before going into a store in winter, and when you come out the interior is nice & warm. Or if waiting in the car for SWMBO, you can keep the heat on without running the engine. My interest was for drag race use, running the heater cools the engine rapidly in summer. The 210 and 140 chassis had this feature as standard equipment, Canadian-spec 211 did as well. Not sure about other chassis.
Code 670, but not in this car though... added afterwards. Why is the question.
https://www.german-spob.de/start.php?artikel_id=5449&seite=gebrauchtteile&seite_gebr=art_details
I could understand why someone would want to retrofit this (I want it too), assuming it works properly. The kit at DE-Spob (1244403309) is specifically for 124 diesels, "ONLY USED WITH HEATING AUTOMATICS AND WITH TEMPMATIK". Tempmatik = manual climate control but I'm not sure what "heating automatics" is.
Might be another retrofit of some sort, or the button controls something else?
I had no idea I had this on my W210. Will I find info in my owners manual? Winter is around the corner.
I really like the grey lowers on this car.
Looking at my DUO Valve, I came across this post.
My take why they never offered this option on the V8s is due to the battery. On the smaller W124s you needed to order the large battery in parallel to the MRA(as they call it). The V8's have automatically the big battery. My guess is the fear that if the pump and the blower run for 30min after a short drive that a weak battery could be too weak to start the engine. While this seems the most logical reason to me, I would wonder why they don't have this issue with the auxiliary heating.
In addition the battery in V8 versions is located in cold place bottom of trunk while its output is be lower compared the battery next to warm engine.
I retrofitted AC control panels with REST-function on both my CLS SB and E Cabrio, every car should have this - not only to keep the car warm, but also to air out the interior for a bit after a drive with wet clothes or on a humid evening.
I realize this is an old thread btw, just really like the REST-function 😄 I read that it was very common for taxis, as they could keep the interior cosy while waiting for customers.
