  • ATTENTION
    Thank you,
    Management
SOLD 1993 500E, Pearl Black/Cream-Beige, 95kmi, MBM auction (Meridian, MS)
gsxr
Sold for ~$37k with fees, see post #14 below.
No affiliation. Pity the headlights are not correct 036 Euro lights, but at least the wipers are correct, and the lights are AL (Bosch), not offshore copies. The recovered headliner seems a bit lumpy was not reinstalled properly, you can see a gap hanging down at the rear of the sunroof opening - not sure what's going on there. New coolant reservoir (NLA) is a nice bonus, and both harnesses have been done, along with a pile of other work. Full stock exhaust is present including factory cats - another Good Thing. Some rust visible on the catalyst heat shield. I hope that $1395 to Fenton was for more than two ZoomTubes, a water pump, and lower harness (ouch!). RMT "remanufactured" the rear shocks, which likely means they did nothing, as discussed in the RMT thread elsewhere on the forum - but if they aren't leaking or rattling, it's not a big deal.
Generally looks like a nice example overall, well maintained, low odometer, rare color combo too. Should be fun to watch this one.
VIN = WDBEA36E7PB860689
Datacard: https://www.lastvin.com/vin/Dw1lNd5wenDK2Rkqy
1993 Mercedes-Benz 500E​
Rare, Thoroughly-Maintained Example Offered From Collection​
This 1993 Mercedes-Benz 500E is one of 1,596 that was produced for this model year. The seller acquired the car two years ago from the previous owner who owned it for 20 years. It was parked for two years prior to his purchase due to a bad water pump the previous owner never got around to fixing. This W124.036 now shows just over 95k miles from new and currently resides in Meridian, Mississippi. Finished in Black Pearl Metallic (199) over Beige Leather (275) upholstery, power is provided by a 5.0-liter M119 V8 paired with a four-speed automatic transmission. Equipment includes factory alloy wheels, a power sunroof, fog lights, Automatic Slip Control, automatic climate control, a Becker cassette stereo with integrated bluetooth, heated power-adjustable front seats, and cruise control. Maintenance performed under the current stewardship includes, suspension refresh including new rebuilt rear shocks, belts/pullies, brakes with stainless steel lines, water pump, ignition service, remanufactured throttle body, alternator, power steering hoses, refinished wood, rebuilt amplifiers, new tires, refinished wheels, and so much more. All three wiring harnesses have been retrofitted. This W124 500E is now offered with the owner’s manual, thorough service records, a tool kit, a clean Carfax report, and a clean Mississippi title.
The body is finished in Black Pearl Metallic (199) with grey lower cladding. The 500E was assembled at Porsche and featured wheel arch flares, revised bodywork, modified transmission tunnel, widened frame rails, and a lower ride height when compared to standard W124 models. Additional exterior features include Euro-spec 500E-specific headlights with wipers, amber corner lenses, integrated fog lights, a retractable antenna, and a power sunroof. The seller notes the front bumper impact strip is showing some wear. The windows are tinted with Xpel with a 35% polarization all the way around and 70% on the windshield.
The car wears factory 16" 8-hole alloy wheels that were built specifically for the W124.036 to fit with the factory widebody kit. All four are mounted with Continental ExtremeContact DWS 06 Plus tires measuring 225/55 all around. The car is equipped with Automatic Slip Control (ASR) and braking is handled by four-wheel ventilated discs.The current owner did a full suspension refresh and brakes including:
  • Lower control arm bushings
  • Front lower ball joints
  • Steering damper
  • Sway bar bushings
  • Shocks and top strut mounts
  • Remanufactured rear shocks
  • SLS fluid service
  • Rear ball joints
  • Stainless steel brake lines
  • Front pads and rotors
The interior is upholstered in Beige Leather (275) and features front and rear Recaro built bucket seats. Amenities include heated and power-adjustable front seats, automatic climate control, a Becker cassette stereo with bluetooth capabilities and rebuilt amplifiers, a power-adjustable steering column, dual front airbags, and cruise control. Burl wood trim adorns the dashboard, center console that have been refinished by Madera Concepts, and each door. A new headliner has been installed by the current owner and the car retains its original floor mats. The original mobile phone can be seen in the center armrest.
The four-spoke Speedline leather-wrapped steering wheel frames a 160-mph speedometer, a tachometer with a 6k-rpm redline, an analog clock, and gauges for oil pressure, coolant temperature, and fuel level. The six-digit odometer shows 95k miles.
The 5.0-liter M119 DOHC V8 was factory rated at 322 horsepower and 354 lb-ft of torque. Power is sent to the rear wheels through a four-speed automatic transmission. The most recent services performed by the current owner are:
  • Water pump
  • Distributors, wires, and plugs
  • Camshaft oil seals
  • Valve cover gaskets
  • Upper timing chain rails
  • All new rubber vacuum lines
  • Remanufactured throttle body
  • Lower wiring harness, upper wiring harness was done previously
  • OEM engine mounts
  • Power steering hoses
  • Transmission gasket, fluid, and filter
  • Oil service
  • ML55 upgraded alternator
  • Serpentine belt, belt tensioner, and idler pulley
Additional services performed under care include the following:
  • Replaced shifter bushings
  • New trans filter/ fluid / differential fluid
  • ECU capacitors replaced
  • New dimming rear view mirror
  • Correct OE euro headlights with rebuilt euro wipers
  • Rebuilt radio antenna
  • SS brake lines
  • New OE fog light lens
  • New thermostat / coolant bottle
  • Rear lower suspension control arm joints
  • New sway bar bushings
  • Power steering filter and hose
  • Suspension filter and fluid flush
  • Rear license plate panel delete look w/spare panel included
Older service records from the previous owner plus hand written notes are shown in the gallery below dating back to 2000. Also included are underside photos showing the condition underneath.
The Carfax report shows the first entry in September 1993 when a title was issued. There are no accidents or damage reported and registration history shows Texas, Loiusiana, and no Mississippi. All three wiring harnesses have been retrofitted. This W124 500E is now offered with the owner’s manual, thorough service records, a tool kit, a clean Carfax report, and a clean Mississippi title.
The MB Market Insights​
The 500E/E500 is one of our favorite sedans of all time. There, we said it. You probably think it is true as well if you’re reading this. We’re also Porsche enthusiasts, so the W124.036 is the perfect blend of two Stuttgart brands we revere. The engineering and logistic story behind the car makes them truly special and the performance backs it up. This 500E is such a sweet spot of not having too many miles, is in the right color, and has been combed through by the current owner having fixed all of the niggly little .036 issues that comes with the territory. Wiring harnesses are the biggest enemy of a 500E and one that spooks a lot of buyers if it hasn’t been done. The refinished wheels, quality window tint, good tires (the Continental is the best tire available in that size), new headliner, and mechanical work are huge pluses. Taking a car to a shop to have all of the work done that the owner did on this would be in excess of $10,000 easily. This appears to be a clean example that is turn key and ready to drive with good documentation and provenance. If you’re in the market for a pre-facelift, this is the one.
More photos and CarFax.
  • CarFax_WDBEA36E7PB860689.pdf
Thanks for making the post @gsxr. Happy to answer any questions. Been a long time member and own another 124036 so know these cars well. Downsizing the collection. Someone will get a car with majority if not all deferred maintenance done.
There is no delay in engaging reverse, no rear glass delamination.
Yes, Mr. Fenton was expensive but didn’t have much choice. All parts from the dealer or OE equivalent. Parts are very scarce. Rebuilding the front controls arms with bushings and ball joints from the dealer. I was surprised the motor mounts had “BBB” stamping.
The rear shocks were sent back to RMT 3 times and finally riding smooth. Headliner looks fine in person, not sure why pics made it look lumpy. It is secured at rear of sunroof and installed properly.
Sad to see you are selling, but nice to see so much work invested in getting the car properly sorted! I didn't realize you had to send the rear shocks to RMT three times - that's crazy. You should post more info on the RMT thread (link). At least it's all fixed now.
BTW - screenshot below of what I saw in the photos. There's a "lip" at the front of the headliner that should hold it up against the sunroof frame. Looks like it just needs to be seated properly, unless the photos were taken prior to this being attached.
Car looks REALLY nice overall.
:rugby:
500Eboard PunchList™
  1. NOTE: Car has “Euro” headlights, wipers, motors and panels installed
  2. NOTE: Car's windows are tinted all the way around
  3. Car has incorrect pedestrian W124 Euro headlights/lenses installed
  4. Front turn signal lamps are dark-orange “Euro” models
  5. Black paint on front bumper rub strip appears tired / in need of refinishing
  6. Underside of rear bumper appears slightly bowed out on passenger side
  7. Various small marks and scratches on rear bumper rub strip, driver’s side
  8. Bottom edge and lower front of front spoiler appear to have typical curb scrapes, scratches and other minor damage
  9. Sunroof seal showing white wax residue throughout seal surface
  10. Various body crevices (example: driver’s side C-pillar cover) showing non-removed wax residue throughout
  11. Right edge of “PREMIUM UNLEADED GASOLINE ONLY” sticker inside fuel flap door beginning to peel up
  12. Driver’s side door pocket edge peeling
  13. Rear edge of driver’s door sill plate lifting off of windlace; dirty on top surface
  14. Surfacing appears to be worn off of steering wheel leather at front left portion where airbag mates up; steering wheel shows hand wear, scrapes and such
  15. Driver’s seat outside bottom bolster and seat-bottom leather should be cleaned
  16. Very slight thread lifting at upper driver’s seat bolster on outside seam
  17. Passenger side door pocket peeling
  18. Sunroof fabric liner needs re-positioning
  19. Passenger side front dashboard speaker grill appears dirty/dusty
  20. Stock rear view mirror has been replaced with aftermarket model with Homelink capability
  21. Front and rear center console wood has been refinished
  22. Phone compartment in center console appears to be missing one black plastic hinge retaining strap
  23. Car is missing yellow emissions sticker on radiator support, passenger side
  24. SLS hydraulic fluid and windshield washer reservoirs are extremely dirty
  25. Air intake tubes are not original to the car; these are later “facelift” model air tubes
  26. Interior B-pillar material is peeling off of B-pillar surface next to driver’s seat
  27. Incorrect hood pad (diesel hood pad superseded for all W124 models) installed; proper 500E should not have foil square
  28. Rubber grommet on vacuum line not installed into edge of front engine top cover
  29. Appears that fuse box underhood is not fully latched closed at clasp
  30. Brake fluid appears SLIGHTLY overfilled at MAX line
  31. Rear brake lines have been replaced with aftermarket stainless-steel examples
  32. Surface metal cover of catalytic converter pipe aft of crossover pipe appears to be eaten away
  33. Transmission tunnel blanket appears scraped/damaged near transmission oilpan
@cascade thanks for punch list. I installed the darker turn signals but originals will be included, also original US headlight trims.
I cleaned the sunroof seal and door jams for any wax residue.
Rear view mirror was updated to homelink version.
Sunroof fabric is now correctly attached. See pic
Emission sticker is missing - any idea where to buy or get a reproduction?
Original zoom tubes included with car.
SLS bottle replaced with a new one and cleaned washer bottle.
Cleaned passenger speaker grille.
Rubber grommet installed on engine cover.
Closed fuse box latch
Corrected brake fluid level.
Rear and front brake lines are stainless steel type.
So the "punchlist" isn't really a punchlist. Near perfect car sub the headlights, which is a minor task for the new owner whether they decide to go US or Euro spec. Obvious the seller is a board member and well versed in the car/platform. GLWS. Hope the car stays within the community.
@cascade,
IMOP, Item #25 should not be on the Punch List. The original zoom tubes were crap and after they became linked did not allow enough air to the motor. The plastic zoom tubes were an upgrade to the M119 and will not collapse.
I feel like the original foam ones were MB's choice to quiet down the engine induction sound anyway, so in my view they should never have been on the car. The plastic ones sound a tad more raw and aggressive, in my view more befitting the car.
;-D
Sold for $35k, with fees the total is $36,575... add TTTT and it's around $40k all-in.
I'm surprised this didn't get more bidders, or bid higher. I'm writing it off as anomaly for the time of year. All bids below... six total, one single bid each. Weird!
$35,000 = Locochonbg
$30,000 = deepgreenmachine
$25,500 = Locochonbg
$25,000 = PB42
$20,500 = Smcase22
$20,000 = amusicianslife
I mean, the Carfax showed a potential flood (see undercarriage) and mileage inconsistencies. Those two things would scare off big money bidders, which leaves you with what you had — the proletariat.
I think the car is worth more, but that Carfax would make me wonder.
All cars registered in LA during Katrina will have a “potential flood”warning. Seen it many times. Mileage is correct on the car.
Out of garage space otherwise would have kept.
The sales statistics for the 124.036 on this auction platform are not particularly encouraging.
I tend to see this more as a platform-related issue rather than a seasonal one.
p.s.
The only successful exception was—yes, as you can probably guess—the sale of an E500 that belonged to the owner of this auction platform.
All cars registered in LA during Katrina will have a “potential flood”warning. Seen it many times. Mileage is correct on the car...
That's messed up. I feel your pain.
My car is branded flood title though it was never in a flood. There was flood declared near to the zip code where the car lived in '95. "People" think it was used as a justification for insurance. The car ran the One Lap of America race as a RENNtech entry the next year 👀 -- the only 500E ever to run that race. "Things happen" in the parlance of the day.
It just means I got a great deal on the car and have been free to drive and maintain it as I please. Hopefully having gotten a good deal the next owner of yours does the same.
