FOR SALE 1994 E420, Smoke Silver/Parchment, 220kmi, $5k (Spokane, WA)
Alphasud40
Moderator update: For sale by new owner June 2026, now $5k, see post #4 below.
1994 E420, Smoke Silver/Parchment, 206kmi, $4k (Spokane, WA)
Looks to have potential as a daily. Exterior looks clean. No ASR, no heated seats.
VIN = WDBEA34E8RC103123
Datacard: https://www.lastvin.com/vin/Mm8YVdBwzmoNEJaKy
Same dealer has a 12-cylinder W140 for sale, $11K. Looks a bit rough. It would cost so much to get that W140 in shape, that it's probably better to just part it out.
Looks like this car is available again 1994 mercedes-benz e-class for sale by owner - Spokane, WA - craigslist. Other than the AC issue and the snow tires during the summer, it looks like it's worth looking at as a DD. Fixing the AC of course could almost double the cost of the car. It's not too far away from me (Seattle) so I may take a look depending on what I hear back from the seller.
Rare 1994 Mercedes-Benz E420 - $5,100 (Spokane)
Rare 1994 Mercedes-Benz E420 in excellent conditions.
Clean title in my name.
Very well kept, no leaks and drives like brand new 💪.
Service records available.
Original window sticker.
New tires.
All gaskets including the head gaskets have been replaced.
Transmission was also serviced, new fluids and the pan gasket was replaced.
This Mercedes-Benz runs, drives, accelerates and stops like new.
Never wrecked or damaged.
It is so hard to find this kind of E-class in this condition but hey 👋 you found one now!
The only issue is the AC. I don't know if it needs freon? Fuse? Relay?
Heat works great!
The vehicle was inspected to the standards of Mercedes-Benz (see photos)
Asking $5100.
Let me know if you have any questions.
contact name: Baker
Cell: (509) 342-4080
Looks like a pretty good deal given the current market values. I would assume 'head gaskets' replaced are actually valve cover gaskets, not cylinder head gaskets, unless there are invoices to prove otherwise. AC repair may not be that bad, unless you are paying a shop, in which case prepare to BOHICA. Minor evaporator leaks can often be cured with sealant, but if it's a slow loss of refrigerant, there's a good chance the leak is elsewhere.
:pc1:
Can’t tell if there’s any clear coat crazing in the smoke silver paint. Overall the car looks great. AC could be a costly problem. Hopefully an EZ Fix.
