  • ATTENTION
    Thank you,
    Management
SOLD 1994 E500, Smoke Silver/Parchment, 45kmi, BaT auction (Walla Walla, WA)
gsxr
UPDATE: Sold for $81k including fees.
No affiliation. Car looks much nicer than average, as it should for the low miles. Only item that jumped out at me from a quick look was the wrong tire size, 235/45 are mounted, should be 245/45. Also, need confirmation if the harnesses and ETA are original or not.
Opening bids are already up to $40k within hours of the auction going live.
VIN = WDBEA36E1RC106264
Datacard: https://www.lastvin.com/vin/5ognYdmOBY62Ozr3W
27-Years-Owned 1994 Mercedes-Benz E500
This 1994 Mercedes-Benz E500 was purchased by the seller as a certified pre-owned vehicle through Sutherland Motors in Spokane, Washington, about 27 years ago, and it now shows 45k miles. The car is finished in Smoke Silver Metallic over beige leather, and it is powered by a 5.0-liter M119 V8 paired with a four-speed automatic transmission. Equipment includes 17″ Lorinser wheels, a power sunroof, a self-leveling rear suspension, Automatic Slip Control, automatic climate control, a Becker cassette stereo, heated power-adjustable front seats, and cruise control. This W124 E500 is now offered with a clean Carfax report and a Washington title in the seller’s name.
The E500 was designed and produced in collaboration with Porsche, with final assembly completed by Porsche in Stuttgart. This example is finished in Smoke Silver Metallic (702) with darker lower cladding. Additional exterior features include headlights with washers and wipers, integrated fog lights, a retractable antenna, and a power sunroof.
The 17″ Lorinser wheels are mounted with Toyo tires. The car is equipped with Automatic Slip Control (ASR) as well as a self-leveling rear suspension. The E500 featured a wider track and lower ride height when compared with other W124 models, and it shared its front disc brakes with the contemporary R129 SL.
The cabin features heated power-adjustable front seats upholstered in beige leather along with a color-coordinated lower dashboard, door panels, and carpeting. Amenities include automatic climate control, a Becker cassette stereo, a mobile phone, a power-adjustable steering column, dual front airbags, and cruise control. Vinyl trim is separating from the driver’s door panel.
The four-spoke leather-wrapped steering wheel frames a 160-mph speedometer, a tachometer with a 6k-rpm redline, an analog clock, and gauges for oil pressure, coolant temperature, and fuel level. The six-digit odometer shows 45k miles, approximately 18k of which were added under current ownership.
The 5.0-liter M119 DOHC V8 was factory rated at 315 horsepower and 347 lb-ft of torque, which is sent to the rear wheels through a four-speed automatic transmission. The Carfax report shows no accidents or damage.
Rest of photos and CarFax.
  • imgi_483_1994_mercedes-benz_e500_1994_mercedes-benz_e500_image000000-1-90617-90734.jpeg
  • CARFAX_WDBEA36E1RC106264.pdf
Sold for $77k plus fees, or a bit under $81k with fees, plus TTTT makes it mid-$80's total. Pretty strong price, but I suspect the odometer played a large part in that. A less beige color combo might have gone even higher. Possibly purchased by a dealership? 3 bidders in the mid-70's. There were large gaps below that point. Had the right people not found this auction during the 7-day window it could have ended much differently.
Top bids:
$77,000 bid placed by Jordanmotorz
$76,500 bid placed by GeriKuqi
$75,000 bid placed by AHG2
$64,000 bid placed by FincaNido
$50,000 bid placed by Mylotimer
$47,600 bid placed by Gregg_Prokop
$45,200 bid placed by hausblau
:strawberry:
My Italian delivered 1995 LTD has this alarm LED
I believe this alarm setup was at least optional ROW, but I'm not sure if it was standard equipment after a certain production date, and/or in certain countries.
:gsxrepc:
Similar threads
