Test or call me at # 860-202-4554 for a faster response. I can get more detailed pix if desired, to text.
NOTE: These are pick-up only in central Connecticut, 10 minutes from Hartford.
2 rims in excellent shape. Selling as a pair. I am the original owner of these. The 275mm Michelin Pilot tires are old and good only for burnouts at this point. I'm not removing them if there is tread still, and there is !
These are original condition, not refinished. Super clean. No cracks anywhere, especially around the lug areas. Only 1 slight small scuff on the clearcoat on an edge. Looks like the clearcoat could be 2000 grit wet sanded and polished...or spend the 100$ or so to have the edge re-finished if you foresee it keeping you up.
$2000 firm
$2000 firm
