OK caveat to this is I bought this as a bit of fun and this thing could be junk!!
I wanted the trans and was told I "had" to take the m104 engine also with it for +£25
It has been outside for maybe up to 6 months! In rain and all sorts. Not covered - yes not good.
I did check the trans and it has a couple quarts clean ATF in it and no water inside so that is good. Engine has water filling up the intake
This is how it sat at their yard. I'm going tomorrow to collect it. I will pump water from manifold before they lift it.
I am thinking of drying it out and plug wells. Pull plugs, put scope down to check for rust/ water damage. Same thing for sump plug check if the crank is all rusty or not.
Then maybe use Diesel or ATF in the bores for a couple days before gently trying to bar it over. Dont want to hurt it if by a small chance it's still a serviceable spare motor.
Thoughts on what I should be doing (besides running away!)
