Project W126 SEC
Hello gentlemen!
I’ve been very busy this past 2 months. Mainly because I’ve been collaborating with a client to attempt for making a modernization of W126 SEC.
I know I have been not so active on
126board with post updates on this project like I usually did on 500E mainly because of workload I’ve been facing like never before. I will upload final renders here for now and then I can upload the details later on the 126board.
Let’s begin with introduction. First of all, are some of you
Boston Celtics fan? The main NBA player in the team is Kristaps Porzingis who is also a Mercedes enthusiast and has special love for the classic over-engineered C126 models that was designed by Bruno Sacco. He currently has Koenig in his collection where he proudly shows up on his
instagram profile
He saw my work and was fascinated by the E900E designation so we teamed up together and make the same for the W126 SEC too. The goal is that he wants to do a complete high quality bespoke restomod for one of his W126 SEC with serious power in. While still have not decided yet what engine exactly to put in.
As you can see the result, in 2 months work I did the exterior work that was by help of 3D-scan of the stock. Then later on I made attempt to modernize the car by help of the sketch I made to ease the work.
The interior work was very easy because I used parts from W124 such as seats, buttons, roof console and so forth that saved me much time. Trims are filled with carbon fiber parts. The only challenged I faced was the belt extension and rear trim of a coupe that is pillar less. But I managed to get the result in the end.
Drive train: I suggested that we pick M177 engine for the visual sake ( I’m aware that it will rise more complexity of the installments and hence its why we see more of M113k swaps for the majority of classic cars)
I’ve installed M177 engine with 600 hp. And install some components in and partially used use some of the W124 parts to fit in to correspond for the original SEC such as windshield washer, brake pump, fuses, brake fluid and so on. Then the rest is modern components for the M177.
Realistically, I needed to raise the hood for the engine to fit in. By 30mm approximately. I made exception for this case for not touching the hood. The main goal was to attempt a modernization bodykit and the engine is to for the visual sake to inspire the future.
In the engine bay, I installed additional metal frame for the sake of collision impact and to strengthen further for the rigidity of the car and handling.
