Hello everyone,
I'm new here and recently sold my last 124. This forum has been such a blessing to help me get my W140 S500 back on the road it's amazing. Thank you so much for this!
I have another particular problem with my gearbox.
A little background:
My 1994 W140 came into life as an S420 and was rebuilt into an S500 15 years ago. It was in terrible shape when I bought it (broken chain guides, transmission pops, differential makes noise, bent driveshaft, etc).
Now I've finally got it running almost perfectly.
The current mileage is 341,000KM.
What I have done in the 9 months of ownership (not driving of course
-Used but partially rebuilt transmission (~190,000KM)
-new differential with very little play
-new used drive shafts
-Used, but very good cardan shaft
-basically everything made of rubber (engine and diff mounts, flex disks etc.)
The problem is this, and I can't figure it out:
When I slowly roll to a stop (low rpm) and shift into 2nd gear (basically under no load), the differential makes a clunking noise. It‘s barely noticeable to the body, but to the ear it is very much.
Also, the upshifts are quite hard and I have to put my foot down quite low (3/4?) to get the engine above 4000 rpm. But that may also be normal (I usually only drive 722.6).
This clunking has improved with the new differential.
I also had this problem with the old gearbox. Even more so with the old differential, but that had a lot of play.
Tried things out:
-partially overhauled gearbox
-Whole rubber
-Modulating pressure valve (set to standard)
Things on my list to check next:
-Check bowden cable tension
-Adjust modulating pressure valve to soft (might eliminate my hard upshifts under normal/slightly increased acceleration)
The transmission tech's explanation (he used to work for MB, so should know a bit about it), told me it's the play in the differential. Although I replaced it yesterday and the problem is still there, but got a bit better.
Are there any known issues related to this? I've searched for hours and only came across one guy who had the same problem 15 years ago but never got it fixed.
Something else I should perhaps mention:
I haven't measured the vacuum system yet and haven't really had the opportunity to do so. If anyone can tell me the best way to do this, I'd be delighted.
The EZS and LH module are still from the 420, but I have both here from a 1992 S500. Could that be the cause? Probably not.
Many thanks in advance!
Tried things out:
-Whole rubber
