Hi,
I'm looking for some guidance on pinpointing exactly what the issue is with my A/C. I've reached the point where I need the help of those most familiar with this chassis in specific.
Some quick details on my predicament, the car is a 1994 E500. I've verified that the climate control is working and that my compressor is in fact turning on when the climate control is set to the proper settings. I've extracted the refrigerant and added dye to system when I recharged it, to pinpoint a leak, if there is one. No leaks detected thus far.
I should note that the system had the correct amount of refrigerant in it before I started this process. Under no circumstance do I get any cold or even cool air for that matter out of any of the vents. The air coming from the outer vents on the dash are at a significantly higher temp consistenly than the center dash.
Any thoughts or guidance is appreciated. I'd like to try and repair this on my own before I'm forced to turn this over to a shop. This is peak driving season here in the northeast and I'd like to make the best of it, but without A/C that wont happen.
