a/c pressures needed ...
Ertech
Hi guys did a search but could not find there answer .
my car was a little low on r134 . I added some but I think to much . do all cars use the same pressure charts?
what high and low pressure should I aim for a 80F and where is the high pressure port?
thanks
Erick
System pressure chart attached. Good to download and print out.
All cars using R-134a should use the same pressure chart. This is not 100% exact, but should be a good guideline.
If your system reads 5-10 PSI lower or higher than the guidelines in the chart, that is likely OK.
For R-134a, you really NEVER want to see your low-side pressure below ~30-35 PSI, or your high-side pressure above around 275-300 PSI, at most typical ambient temp levels.
For R-12 (older cars, no E500E ever left the factory with it) system pressures are somewhat lower on both the high and low sides.
