Forum search function:
[ATTACH type=full alt=Screenshot 2023-03-13 at 11.13.14 AM.jpg]162796[/ATTACH]
For everyone with a LH Mercedes this might be of interest- Early on after buying the 500E I contacted Mike K (HFM Scan) and enquired if his software would read a 500E Live Data. Long story short I have been assisting Mike with Data from my 500E over the past couple of months and he has been...
www.500eboard.co
Not sure where you got the other information, but per their web site, I do not believe it will work with CIS-E-based systems (M103) and only supports HFM-based (M104, M111) and some LH-based (M119) systems.
For M103 and M117 generation engines, you can only use a home-made straight blink-code reader (or a compatible system such as the Trisco PalmScan or MB STAR C3 with compatible cables) to pull codes.
M103 / CIS-E Duty Cycle readings require a digital multi-meter with duty-cycle capability, which attaches to the round black connector on the inner drivers fender-wall.
Or, you could use the rare-as-hens-teeth Bosch KDJE-P 600 tester, which per the photos below plugs right into the X/11 connector on the fender.
