Greetings friends…
I have replaced injectors, fuel pumps, and upper engine wiring harness on my 93 400E. Afterwards, the engine runs perfectly in open loop, but runs like a lean condition In closed loop. I press the test button on the 8 pin diagnostic socket, and the LED light comes on. After releasing the button, there are no flashes, including the single flash for a good circuit.
At the 38 pin connector, no flash codes are present on circuit 19, which involves the LH injection, and there is no single flash for a good circuit. I replaced the “carb module” under the passenger side foot well, and there is still no flash for a good circuit. I substituted several LH injection modules without success.
At this point, I am suspecting that the replacement upper engine harness may be defective, but I have no idea whether or not the harness is carrying this circuit. I would appreciate any suggestions regarding the voltage source for the test light on the 8 pin diagnostic terminal or circuit 19 on the 38 pin connector.
Thanks!
Thanks!
