SOLD Assorted special tools for Mercedes
gsxr
Cleaning out the shop... have a few duplicate tools. All are used, and may not be pretty, but they are functional. Details & photos below.
All prices are in USD and include free shipping within USA only. Please send me a PM (conversation) if you want a quote for international shipping, which may be expensive ($50-$75).
1) Rear wheel carrier support joint tool, Genuine Mercedes, p/n 202-589-00-43-00, good condition. Click here to see tool in action (links near bottom).
**SOLD** (new from Naperville is $182)
2) Rear wheel carrier support joint tool, Sir Tools M0082, equivalent to MB p/n 202-589-00-43-00, fair condition, some external dings.
**SOLD** (new is $120-$130 from most vendors)
3) Rear wheel bearing tool, Miller 9199, equivalent to MB p/n 124-589-05-43-00, good condition.
**SOLD** ($250+ on eBay, $600+ from Naperville). NOTE: This tool only R&R's the bearing as seen here. You need to use other methods to remove the hub.
4) Differential rear mount tool, Miller 9113, fair condition, minor external corrosion. For 66mm diameter V8 bushings only (not 4/5/6-cyl W124 bushings).
**SOLD** ($75-$90 on eBay) NOTE: Tool center shaft is ~0.5mm larger than bushing hole! Bushings must be drilled to use shaft supplied with this tool, OR use a different threaded shaft.
5) Rear hub flange puller set, Miller C-637CF Slide Hammer & 6790 adapter, excellent condition
**SOLD** ($100+ for both on eBay). NOTE: This setup will NOT remove hubs which are seized into the bearing!
6) 38-pin breakout box / mushroom tool, Genuine Mercedes, p/n 140-589-14-63-00, good condition
**SOLD** ($200+ on eBay, $355 new from Naperville, Chinese equivalents available for much less)
:banana1:
Item #4, differential rear mount tool:
If number 6 didn't get purchased, I'll get it as a third mushroom (two reserve units + 1 garage tool) for my deep parts stock.
Sorry for the delay, folks. #6 is pending sale from international buyer. We were working out shipping arrangements, ended up going with a freight forwarder. Payment should be received in the next few days, I will update again once it's all finalized...
UPDATE: #6 is sold.
:tumble:
You're SOL, @nocfn! I'll sell you one of my mushrooms, but it will be $300.
I wonder who the W124 nerd was who bought the hub-puller slide hammer and the rear wheel bearing puller tool.
Dave,
I'll just let you know that the 38 pin mushroom and the subframe bushing tool arrived last week, and all parts was exactly as described. The packing was really good - the mushroom tool made of plastic and alu. could easily been damaged by the sturdy bushing tool of steel, so kudos to you for the packing. The tools comes nicely along with some other tools I've scored from you over the years as well, have to prepare another box for them too.
The Miller 9113 Rear Diff Mount tool is the only one that is still currently unsold, correct?
Dave, I'll just let you know that the 38 pin mushroom and the subframe bushing tool arrived last week, and all parts was exactly as described. The packing was really good - the mushroom tool made of plastic and alu. could easily been damaged by the sturdy bushing tool of steel, so kudos to you for the packing. The tools comes nicely along with some other tools I've scored from you over the years as well, have to prepare another box for them too.
Thanks for confirming, Arnt! I was really nervous putting such a heavy tool next to a fragile item, so I did everything I could to try and make sure the package would arrive intact. Glad it made the trip safely. And your tool storage is amazing - wow!
Correct. This tool is the last item available.
These large V8 differential mount bushings are not common failures. MB radically upgraded the V8 bushing compared to the stupid-small 4/5/6-cyl bushings. The "little" bushings are a very common failure. But I do wonder if old V8 bushings may have hardened over 30 years and could contribute to driveline vibration. Next diff I have out I plan to swap these suckers.
:sawzall:
Dave,
Well, those tool boxes may appear a bit nerdy, but I don't have any tool cabinet so this was an alternative to store these tools. The special tools are in fact not used that often either, so the boxes keeps them clean and sorted, and it's pretty handy to carry on whenever needed. The red box at right was originally for the BAUM squeek bushing tool, and the other box can be found in various sizes at any hardware/freight store, the foam as well. So it's just an entertaining cut & arrange job. I have another two boxes for the wrenches and pliers, not as organized as the special toolboxes, but that became a great improvement for the wrenching. Made it simpler and faster to pick the right tool compared to digging around in the huge toolbox. For smaller fixes on the cars, bicycles, house... I load a small handy toolbox with the needed tools instead of dragging around the ship anchor heavy toolbox.
..just my "2ool" cents :banana1:
I've got two of them sitting here, but at $6.00 apiece from MB new, it's hardly worth the effort to send them in the mail.
CRT warmed up. :D
Louis, if you are serious, it's yours... can include the requisite gray door switch as well. You've got my email...
:jono:
