Hey guys . I appreciate the help in fixing my previous issue a couple of months ago ..I am almost done with the restoration but I have a check engine light that keeps coming on even when I clear ( POS and neg for 15 sec ) or just using the code reader ..It idles without a miss . A bit sluggish at times from take off . In the morning the car will not idle up . I mean when crank it in the AM, the idle is only around 700 and probably comes down to 600. I was able to reset some codes on a few modules but not all . I also replaced the mass air flow sensor and I am getting same results .. I have attached the codes from the modules I tested .on the very bottom of the page where it says "Reset button " was the code I received from pushing the reset button on button next to the 38 pin diag connector . I am thinking Vegas module but I may be wrong . I replaced the megas module from my parts car and the idle shot up to around 1300 rpm ( parts car is ASR) I have since put the original back in . Plz help . See attached pin codes from my eBay code reader
