Battery charge
Should be closer to 14v, but in general anything between 13.5-14.5 is normal, assuming your meter is accurate.
EDIT - this is with the engine running, see post #4 below.
Dave, are you talking about the alternator output or the battery voltage itself?
Oooops, good point, thanks Jon! I meant 13.5-14.5 measured at the battery, with engine running.
With engine off overnight, the battery should read at least 12.6 volts. If the engine has not run in days or weeks the voltage may be lower, and the battery should be charged before testing.
:doof:
