So I appreciate everyone's help up to this point. Now I am trying to track down a drain issue. If the car sits for a day without use the battery will fully die.
So I jumped it and it runs and charges, which is good.
the way I typically track down drains is unhook the negative cable and place a test light between the negative pole and negative cable. If the light is illuminated it shows a draw. So with the light connected I started pulling fuses, but I couldn't get the light to go away, i did get it to become less bright, so I know the clock and some other stuff with pull power all the time. So I am stuck at what else to check..,any ideas? Thanks
KDAWG
KDAWG
