Turn signals issue
yevgenievich
Have an issue with turn signal that does not appear to be very obvious. Hazards work and turn signals do not. If I feed the circuit by connecting pin 30 to 49a on the flasher, turn signals will light up using the stalk(just no flash). Bypassing flasher switch correctly and turn signals do not work. Tested the multithing relay and does not appear to be a problem there. Thoughts?
Have you tried swapping the combo/flasher relay with a different one yet?
