Hey there folks - been a while since an update
Over the weekend, I did the sway bar bushings. This was a piece of cake job - took maybe 2 hours tops, taking my time and enjoying the weather. The car had a box of parts when I bought it which included the inner bushings (Meyle part). I ordered the outers from AutohausAZ (Lemforder) because I was having trouble finding the OEM part numbers. The best numbers I could find are:
The inner ones seem to be NLA. I did find a "close" part number, but I'm not sure if it fits.
When working with the 13mm bolts to loosen the bushings, the inners you have to counter hold - the outers you don't. When you put the bar back on, both have a torque spec of 20nm.
I captured a video of the process. It was fun and wow- my old ones were shot bigtime. Shrunk, cracked, falling apart. You can see how it looks in the video
I just got two sets of control arm bushings in. I'm going to remove both front control arms next and then replace those and the ball joints. Will need to get comfortable with the spring compressor! You can see the sad state of the control arm bushings in the video - the leaky steering gear box made them swell up and fall apart.
I've kept the part number listing (a few posts above) for the OM603 #20 head up to date. I've gotten most of the parts in at this point... just waiting for the valve stem seals and the spring retainers. Trying to source some of these parts is crazy - the project feels like it's moving in slow motion. Once those final bits come in, I'll do another video showing all the parts and then it's off to a machine shop (need to find one in Phoenix area).
124-323-49-85
(outer, the skinnier ones)124-323-56-85
(inner, the bigger ones)
124-323-45-85
