Benz part number of a stupid little elusive bracket?
Velvet Pants
See the little bracket circled in the pic below? It holds the wiring harness to the front corner of the valve cover. That bracket - what is its part number? Can't seem to find the bracket on EPC at all.
It was found on M156-powered S63 and CL63 (or any of the front-sump M156s). MY2008-2011, or thereabouts.
(oddly enough, the part number stamped into the similar bracket on the other cyl bank is A1561590340... but this p/n doesn't show up on EPC or anywhere else. what the what?)
...(oddly enough, the part number stamped into the similar bracket on the other cyl bank is A1561590340... but this p/n doesn't show up on EPC or anywhere else. what the what?)
Reminds me of the situation I had with the M119 throttle motor connector. Although there clearly is a part number for it you can't find it anywhere in EPC. Regardless we placed an order for it and indeed it showed up. So if you have not done so already you should try doing the same with the this part. Nothing really to loose by doing so.
Sent from my XT1254 using Tapatalk
I would do that but I don't know what its part number is.
If anyone gets one of these S63/CL63 rigs in for service, I'd love it if you could crane your neck and write down the passenger side bracket's part number. Or, tell me if said bracket is kicking around at your local boneyard (AHAHAHAAHAHAHAAHHAHA).
