Need to replace the front brake pads and the Porterfield R4-S pads (AP847 for SA brakes) I received have the holes for the sensors closer to the backing plate on two pads and two pads have the holes towards the center of the pads. Shouldn’t all four holes be closer to the backing plate? With the holes towards the center of the pads, the length of the sensor wires is too short and the sensors will not be locked in place in the pads. Plus the holes in the middle of the pad will shorten the pad surface life before the pad sensors are triggered. Do all four pads need to have the holes closer to the backing plate, for the four sensors? The below image shows the location on the hole in the middle of the two pads I got and two pads with hole closer to the backing plate.
