Guys. Having a issue with misfire and rotor arms.
Replaced rotor arm and distro cap on Left side. Ran fine for a few kms then started pulsing, very soon after would not take any throttle and was no power - acted like in a limp mode
Pulled off the distro cap and found the new rotor arm had burnt at one of the screw holes
Replaced both rotor arms. Started perfect, idle perfect, quickly started pulsing at around 80kmph. And shortly thereafter again not taking throttle, no power and again misfiring
This time the new rotor arm on the right cylinder bank has burnt - in exactly the same way as the other one did. The left side is perfect.
Rotor arms and cap are Bremi. Photo of the second burnt one attached
Any ideas what could be causing this?
