Car won't go over 4500RPM while running
Godlama
Active member
Hello , my 1992 ( Swiss version ) 500E is having a bit a problem now.
When cold , like extremly cold like first start , I can pull over 4500RPM while driving , but after that.. Car starts to cut and engine shuts down.
I suspect a fuel pump problem , but i'm not sure ? It also feels like the car has not his full power when I try to kick down.
What has been recently replaced :
-Coils
-Spark Plugs ( Straight from MB )
-Spark plugs wires
-Rotor caps. ( it's even worse since )
anybody have an idea ? I'm quite lost in this , for the DTC I tried to pull them out with my SDS , but it seems like I have a connection failure..
Thanks in advance.
Manu.
When warm, does the engine pull to exactly 4500 and then hit a limiter of some sort? And it's always 4500rpm, not higher or lower? That sounds like possibly the computers limiting the revs, maybe due to a signal from the gear position indicator switch (S16/1).
You'll need to get your SDS working to check codes, particularly for the E-GAS module (EA/EFP). SDS will also show live data to verify if the gear positions are reading correctly. You can get basic codes with a blink code reader.
If your SDS has never worked for all modules, you may have a defective 38-pin cable - verify all 38 pins have continuity on both ends (from connector to connector).
BTW, welcome to the forum!
:welcome4:
:welcome4:
Hello , yes it's exactly that 4500 RPM then shutting down , but when I'm in neutral , no problem I can go over 4500.
Ok I will check about it , it's working on ODB2 etc but I guess my 38 Pin is failed.
and thanks for the welcoming help !
Going 4500RPM on cold motor is not what i would do but i may add that engine shuting off after high RPMs would ring a "catalytic converter failing" bell in my head.
Hello I tried without cat , still does the same..
That sounds like the problem. The engine should not go above 4500 in Park or Neutral, but should pull to the rev limit only in gear.
See what other modules you can connect to with HHT-Win. If it will connect to only 1 or 2, you likely have a defective 38-pin cable. Search the forum for details, this is a common problem... the Chinese vendors cheaped out and removed most of the 38 wires to save money, not realizing (or, not caring) that this would render the cable useless for may 1990's vehicles.
If HHT-Win works with every module except EZL/DI, that is a different problem, it can be a defective MUX. This was also discussed in the past on this forum.
I'll try to replace it , do you by any chance got any part number ?
:welcome4:
After reasearch on the forum I found , this part number 000 545 62 06.. By your indications (S16/1) it's the neutral switch that should be replaced ?
(found it here HOW-TO: Replacing Neutral Safety Switch (S16/1) | "HOW-TO" Tutorial Articles)
Don't replace it just yet. ADJUST it first per the FSM procedure here. Then bench test it next. The BEST test method is using SDS / HHT-Win to view live data as you move the gearshift into each gear position.
If you confirm your NSS is indeed faulty, you could gamble on the €300 Kurth modified replacement.
I will do it. I forgot to mention that ; sometimes , when I put the car to D it just won't drive , need to put the selector just a lil bit higher then it's engaging. It's errating.
I'll fix my SDS then I'll come back for giving feedback.
Hello. Little update , I tried to clean the NSS , but It didn't make any result. So I ordered a " new one ' at Kurth classics. Wait and see.. I will replace it and let you know.
Great! Please let us know the part number Kurth sends you. Photos would be great as well. They only have one small picture on their website.
Update , replaced the switch it is slighlyt better now i can get to 5000RPM. But I always have the feeling like the transmission is not fluid. When it s shifting it feels like it get blocked by something , i can feel it , no particular sound but like a " CLOC " when i m shifting , also it feels like I have no kickdown at all... The button of my kickdown switch was loose so I put it back in place , now I have to try it. Any help would be appreciated...
SDS (HHT-Win) will show live data to verify if the gear positions are reading correctly.
This would be the next step, you need to verify the powertrain computers are recognizing the gear position correctly.
:hornets:
SDS is working now.
Do you have a procedure.
How do I know that they are in the correct position?
I really feel like when I pass from gear to gear I have a hard feeling in the transmission.
I will do the check with the SDS then
Thanks for answering.
Your guess would be the transmission module then?
This would be related with the fact that I have no kickdown?
See video and screenshot below. Live data will update in real time as you move the gearshift through each position (P, R, N, D, etc). Make sure these all read correctly, AND that there are no fault codes on any of the modules.
No kickdown is a separate issue - need to verify the control pressure (Bowden) cable is connected properly on both ends, and verify the electric kickdown solenoid is working. If the transmission will remain in 1st gear in "B" position, and not upshift until you move the shift lever out of "B", that confirms the kickdown solenoid/wiring is good and working normall.
There is no transmission control module on these cars, they are fully mechanical. However, the gearshift position is sent to the engine computers, which can result in RPM limits similar to what you describe.
Ok so , everything is normal for when I pass the speedas you said. 2XWX8Bcf_m&_nc_zt=23&se=-1&_nc_ht=scontent.fcrl2-1.jpgqm8vyl5vux&_nc_zt=23&se=-1&_nc_ht=scontent.fcrl2-1.jpghj4IfPGgbA&_nc_zt=23&se=-1&_nc_ht=scontent.fcrl2-1.jpg
For the coil Voltage is weird because it not constant. Sometimes drop to 0 sometimes not and on every cylinder
I m really lost
That's showing a bunch of old, stored faults...what I refer to as "code diarrhea". Clear ALL codes, then drive the car and see which codes (if any) return.
The cylinder voltage intermittently showing zero (or, 9v) is not normal. Never seen that. Normal is 30-40v.
Did the shift positions show correctly in EFP live data, in each gear position?
Yes the PRND position went good no fault.
I try to clear code but they instantly come back. Or maybe I m not doing it good ?
The code pages are obscure because they dont stop. Sometimes I have 1 page sometimes 3 sometimes 2.. I dont understand what s going on..
Do ALL the faults return immediately on all modules? Are you certain the "clearing" process is working properly?
Next question - what part number modules do you have, including the EZL? A photo of the modules in the CAN box (and EZL) may be easiest.
I tried to reset it once more , still not working properly. Seems like I can't reset the codes. When I press reset the codes car shuts down I dont know if it s normal or not.. 🙄
All your module part numbers are correct. I forget if you can clear codes with the engine running, but after clearing, the ignition must be turned off for 10-15 seconds.
What happens if you try to reset/clear codes with the engine not running? Still no change?
Since you cannot clear faults on the EZL, I am suspicious your EZL could be defective. Do you have a spare EZL to test with? It doesn't need to be the same part number, any 5.0L M119 EZL will work. Even an early 4.2L module would work for test purposes.
Unfortunately not , it's not common to find V8's here in Belgium. So if anyone have one for sale / to test around here I will be glad !
I will try to clear them with engine not running this afternoon , wait and see.. I'll keep you posted.
The video still shows bizarre behavior, along with the fault codes. I'm still suspicious the EZL is defective, but I'd hate to have you buy an EZL and then find it wasn't the root cause of the problem. I have a good one available for sale but shipping to Belgium isn't cheap. Might be able to find one in Europe for less.
The LH fault isn't related, but should be investigated further. If the O2 sensor is old or original, it would be a good idea to replace it. If it's been replaced before, double check that the locking ring is FULLY seated. Sometimes you need to use pliers to get the lock ring to "click" into place, fully locked. If it isn't locked, it won't make electrical contact and would cause the fault shown.
Colis are new ones , pain to replace them tho... I put bosch 0-221-502-429 and 0-221-502-431.
Those coils are for older Mercedes ignition systems, only used on the very early 500E, up to chassis #B968955. These require an older / early EZL also.
You need Bosch 0-221-502-433 and 0-221-502-435 to match the EZL in your car. There's a chance your EZL may be ok, but does not like the "wrong" coils installed. I'd replace the coils first, with the correct ones (MB p/n 000-158-64-03 and 000-158-65-03).
Its not the same number the one you show me, not a probleme at all?
Your EZL 013-545-64-32 has been replaced a couple of times, the newest / most recent part number is 015-545-61-32. However, I'd swap the coils first before the EZL. Both of these EZL part numbers require the newer coils mentioned above.
Hello @Godlama
as for track-keeping purpose allow me to add datacard for your 500E (VIN = WDB1240361B677034) here onto this thread, as well as at the VIN Database too.
Best regards,
Alberto
Hello feel free !
1B677034 should use the newer coils / EZL combination.
Your EZL is correct for your chassis.
The coils you installed are not correct, they are the old style, and should be replaced with the newer numbers I posted above.
You are a legend. Like a real one, not one of the fakes one you see on the books. You are made of 100% Knowledgium metal.
The car have now 100% of her power. I never felt it like that 👍👍👍 thanks again a million time.
