Sunroof won't full close unless I use the tilt function
Savethestickshift
The situation is as follows in my 1995 E500 Limited:
Sunroof opens without issue. but when I go to close it, it gets 90% of the way there and won't got last 10% or so.
However, if I then initiate opening the tilt function, it will fully close and then tilt up.
So, I can try to time the opening of the tilt to get the sunroof closed before the tilt initiates.
Also, if it is already tilted up, and i go to open the sunroof, the tilt will retract before the sunroof begins to open. Again, I can try to time it to get it fully closed at that point.
Has anyone experienced this before or have any suggestions?
I have not, but lets hope I don't ever. Is the cable original, have you studied the lifting arms or the tracks to see if there is any type of obstruction in there?
I don't know about the cable and haven't checked the lifting arms or tracks as it just happened today on the way home. I'm going to check this evening. But if there was an obstruction, I can't imagine how it would close perfectly fine when operated from the tilt position...
@Savethestickshift,
Check out @JC220’s thread on R&R the sunroof. I think he is about the only one on this forum that has done this project.
His thread is pretty comprehensive with lots of pics.
