Hello all,
Decided to join the forum to share some experiences and hopefully get some input on my current issue.
My E420 W124 1993 started having some issues about a year ago after a 6 month winter break. It was the usual, limp mode with ASR light on. Back then i diagnosed it to be a faulty ETA, but during diagnosing the issue went away and normal operation continued for the whole summer. I was pretty sure the issue would return, and sure enough, after this years winter break limp mode was back.
I checked the the ETA and the wiring harness was crispy enough to deem it the culprit. I sent it to MBK-TEC for a rebuild, got it back and assembled it. And the issue is still active. From the report it can be seen that there was no difference from pin measurements before rebuild. This would point to the issue being elsewhere, although i dont have a reference point to know whether measurements are good or not.
Additional info:
ASR code 030
Throttle valve angle stuck at 89.2 degrees (value 46 from LH1)
Limp mode / ASR light on (no electrical movement on throttle)
Engine upper harness replaced few years ago
Throttle linkage checked -> throttle flap rests freely
No communication to EFP on star (this could be due to a missing pin 7 wiring on diagnostics cable)
E-gas module checked, no visible corrosion on boards
Next steps:
Check actual values from both e-gas module contact and ETA contact to make sure if throttle position is changing on pins
Help needed:
Wiring diagram from e-gas to ETA to find correct pins
Im thinking that the e-gas module is broken, but i would really like to be certain before getting into replacing or repairing it.
Any other input is greatly appreciated, would not have gotten this far without forum anyways.
Additional info:
ASR code 030
Next steps:
Help needed:
