Thanks, @gsxr I figured that was the case with the manual throttle cable messing around. I wont do it again.
Since the car has been driving fine, I decided to focus on the cooling system.
Based on just checking for resistance, the fan seems to resist movement - this seems to indicate that it is not busted. I dont see any leakage or other signs of wear on the fanclutch. I tried removing the bolt that holds it in place and no dice. I could not get it to budge. While there, I noticed that my belt is definitely due for replacement. So, maybe I will tackle that and do the thermostat at the same time. I wont mess with the fan clutch unless it is definitely confirmed bad. (Yes, I bought an aftermarket clutch
Speaking of which - how in hell do I get to the bolt closest to the block? I lost a 10mm in the space behind the thermostat housing rubber elbow. While fishing for the 10mm with. magnet, I recovered a 13mm bolt. Since I couldnt get that back bolt off, I never managed to replace the thermostat.
** funny story - My last w140 was a 300SD and I replaced the intake and exhaust manifold gaskets on it due to leakage. While doing this job, one of the intake manifold bolts fell into the space between the block and the injection pump. I never found it. I think this bolt traveled through time and space to hide inside my S420. Which means that the next w140 I own will have a 10mm hidden somewhere in the engine bays crevices **
On other cooling system issues, how do I remove the big 4 pin sensor? The sensors next to it are so painfully close, I cant get a wrench or deep socket over it.
I will try to record the whirring sound I have been describing with a mic.
)Speaking of which - how in hell do I get to the bolt closest to the block? I lost a 10mm in the space behind the thermostat housing rubber elbow. While fishing for the 10mm with. magnet, I recovered a 13mm bolt. Since I couldnt get that back bolt off, I never managed to replace the thermostat.
