1992 500E M119
Hey guys!
I have not been on the site in a while. I have not had time to play with my E and it’s had a parasitic drain that I wanted to correct before it becomes a big problem.
That said, I try to drive it once a month or so.
I drove it a month ago, ran fine after it started a bit rough. Drove for 30 minutes and parked it in the driveway. Flew to DC for a week. Returned home and tried to start it the next morning. Cranked, sputtered a bit but did not start.
Fuel pump relay was turning on pumps, pumps made a groaning noise so I pulled them.
Had a bad pump, a second groaning pump. Installed new pumps, new filter.
Gas smelled bad so I drained it and refilled.
It has pressure at the rail, but I didn’t measure the pressure.
I’ve got spark at plugs. Pulled caps and rotors and cleaned up a mild bit of corrosion. No moisture.
Runs for a second if I spray it with maf spray.
Pulled the cap on the CAN box and found some corrosion on a couple pins, deteriorating foam on the pins but nothing exciting.
Crank sensor should be good if I have spark. So I think I’m down to LH module or clogged injectors..?
Thanks for any advice!
Bryan
(DarkStar)
Hey guys!
Bryan
(DarkStar)
