Making progress on this E420. It's running correctly, revving fully, and all dash lights are out - core issues fixed.
Just noticed, the DRL's aren't working (it's originally a Canadian car).
A quick search says the relays are behind the cluster. I swapped the blue one - no change. There is some funky wiring from the PO on the silver one. The female plug is missing, wire ends are directly connected to the relay. An auxiliary ground wire has been added (if disconnected the car won't crank).
I haven't removed any of this yet, as it's awkward to get at, and see fully.
Before I create any new problems, does anyone know for sure if that is actually DRL wiring? (If not, does anyone know where else to look?)
Thanks!
Thanks!
