Hello! Two out of my 4 door cards are only loosely held on as they were clearly pulled outwards in the past by previous owners instead of lifted up. The back left is the worst- I removed it and found that it's only held in by 3 hooks; might have been 2. I can see glue patches where the other clips should be glued on but unfortunately they're nowhere to be found.
I've searched the interwebz and found nothing in terms of buying new ones or any info at all for that matter which surprises me as I thought this would be a common 124 problem.
Has anyone faced this problem and found a solution? Does anyone have any of these door clips or a wrecked door card which they can salvage the clips from? I will buy them if yes.. I mainly need for back left door as the card comes away from the door by 2 inches when pulled shut using the handle.
Henry
Henry
