E60 engine stamp
Yes, to me looks legit. Restamped closed deck block probably (mb serial nbr - strange is only the 60 behind the 12), amg stamping on the backside looks fine. That engine is just a few units ahead of when mine was built. Should be in 94.
Yes, to me looks legit. Restamped closed deck block probably (mb serial nbr - strange is only the 60 behind the 12), amg stamping on the backside looks fine. That engine is just a few unit before mine was built. Should be in 94.
Thanks for confirmation I was not sure if 6.0 was stamp on the front of the block
I think I missed you by few hours ,
Shame would be nice to say hello.
I had a business trip in Dubai so I decide to check the car while here
Your E500 looks amazing
If you’re staying the weekend there is an MB meet on Sunday
If not, get in touch next time you’re in town
exactly this is what I could not remember on mine previous e60 , hence mine doubts
This was discussed recently and I think consensus was the AMG stamp on the rear may be legit.
The question came up because at some point AMG started stamping the front of the block instead of the rear. What we don't know (yet) is when exactly AMG switched from rear to front.
That said, I don't recall ever seeing a random "60" stamp up front by the MB engine serial. Engine #9401 would have been open-deck block. It appears the serial area was ground off and those are new numbers stamped in place, likely to match the original #9401. No way to know if the "60" was stamped at the same time or someone added that later, post-delivery.
