Hi all, I'm going to post this in case someone else has experienced it and discovered a solution. Neither of my guys have.
Issue: after car is working fine up to temp it will bog horrendously for a while. Continued running it goes away.
- Idle becomes very rough, enough to have me put in idle at stop
- Pressing gas sounds like 4 cylinders engaged and moves but slowly. More throttle does not give more power
- above 2500 to 3000 rpm sound returns to normal, but harder throttle it can bog
- manual shifting to keep RPM up helps just to move in traffic
- goes away after 15 minutes running, especially on highway but that's at higher rpm anyhow
- engine light on not sure of code no other lights
- does not happen every time
- otherwise very well cared for and reliable. Known steering pump leak but level kept up easily
- 180k 1992
Thanks for any help you can provide!
- 180k 1992
